CowboyBob Posted August 19 Report Posted August 19 58 minutes ago, friquant said: How much is a new stitch length cam? I've never had a main shaft out...is that straightforward to do? $75.00 w/shpg.the shaft can be hard to get out you need to sand it lightly as it gets rust & dirt on it.Then oil it so it slides out easier. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Contributing Member friquant Posted August 19 Author Contributing Member Report Posted August 19 On 8/18/2025 at 9:17 AM, kgg said: I would get a wire brush and scrap all round the unit particularly around the feed eccentric seam and then add a few drops of good old fashion diesel around the feed eccentric seam. A few hours sitting with a few drops of diesel made a difference! I'm gonna throw away my penetrating oil 😜 I've got 2.5 turns each way now. How many turns should I expect when it's fully loosened up? Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
kgg Posted August 20 Report Posted August 20 (edited) 12 hours ago, friquant said: A few hours sitting with a few drops of diesel made a difference! I'm gonna throw away my penetrating oil 😜 I'm glad the you got it freed up. As far as I'm concerned there's nothing better then good old fashion Diesel. It works better then any of the "penetrating oils" just smells a bit. I would now flush/soak the area with synthetic transmission fluid. That will soak in and flush out the old garbage while lubing. Sorry, can't help with the amount of movement you should have. kgg Edited August 20 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Contributing Member friquant Posted September 2 Author Contributing Member Report Posted September 2 It's getting better! When I got the machine it stitched 8mm stitches. After the first round of diesel it was adjustable from 8mm - 12mm. I'm guessing that 12mm is the maximum for this machine since it seems to come to hard stop there, and it's a "round number". A week or so later I tried again and now it adjusts down to 6mm! Guess I'll keep soaking it as I use it to see if it will keep freeing up. If I can get it down to 3mm that's probably good enough. I appreciate the help Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
kgg Posted September 2 Report Posted September 2 1 hour ago, friquant said: A week or so later I tried again and now it adjusts down to 6mm! Guess I'll keep soaking it as I use it to see if it will keep freeing up. If I can get it down to 3mm that's probably good enough. I appreciate the help Once you get it freed oil it with a couple of drops of synthetic transmission oil. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Contributing Member friquant Posted September 2 Author Contributing Member Report Posted September 2 12 hours ago, kgg said: Once you get it freed oil it with a couple of drops of synthetic transmission oil. I did buy some synthetic transmission oil. Somewhat surprised it's still red. 🍎 But it smells neutral. Actually even the diesel has not much smell when it's just a few drops. I'm not even doing it on the porch---too much strain. Just right in the living room, a couple drops of diesel and then shut the arm cap. Nobody has complained 😀 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
