Members NowhereMan01 Posted September 5 Author Members Report Posted September 5 On 9/3/2025 at 7:12 AM, CowboyBob said: Put the screw for the eccentric, marked S on the eccentric into the slot (or V on the shaft)once you get it pushed to the left where it belongs & tighten the screw should get it feeding again. Thanks! Although I don't see anything marked "S", there are 2 distinct screws on the eccentric that can be screwed into the slot. The first one I tried resulted in no stepping at all, but the other one seems to work, as it is now stepping, and the stitch length adjustment even seems to be within the correct range too. However, now the bobbin hook is not catching the thread, so I assume that something went out of alignment. Any hints/suggestions on what/how to adjust would be much appreciated. Quote
Contributing Member friquant Posted September 5 Contributing Member Report Posted September 5 11 minutes ago, NowhereMan01 said: I don't see anything marked "S", there are 2 distinct screws on the eccentric that can be screwed into the slot. The first one I tried resulted in no stepping at all, but the other one seems to work You will want to get the correct set screw screwed into the groove in the shaft, as there are timing adjustments downstream of this that will be affected if this is incorrect. Typically there are two set screws, 90 degrees apart on the shaft. I can see the shaft has a groove in it. One of the set screws is meant to be tightened into the shaft groove (this screw often has a rounded tip that fits well into the groove). The other set screw is meant to be tightened against the regular face of the shaft. (this screw will likely have a flat tip) After you get that sorted, I would check that the clutch safety is engaged. And send us another video zoomed in on the needle and bobbin area, slow motion turn with the handwheel like four seconds or so per revolution. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
CowboyBob Posted September 5 Report Posted September 5 I think the clutch is kicked out,take the bobbin out,try pushing on the stitch length button ,turn the handwheel backwards until it goes into the slot,while holding the button down push the handwheel backwards until you hear a click or until it just won't turn anymore.This "should" get the clutch re-engaged. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members NowhereMan01 Posted September 5 Author Members Report Posted September 5 I really appreciate all of the help and I feel like it is very close to being resolved, but it's not quite there yet. Apparently, I did have the wrong set screw engaged with the V slot, and I've now got the slightly-rounded one in the slot. I also did the clutch engagement trick, and I did not hear a significant click (as I saw/heard on a YouTube video), but it did seem to have a small bit of "give" when pushed with some force, so it might have been out. Yet, the issue persists... Here is another video of the bobbin area, with me turning the wheel by hand. LMK if any other view might be helpful. Quote
AlZilla Posted September 5 Report Posted September 5 Looking back through this thread, I don't see where you checked the hook timing. Did I miss that part? It seems to have started with the walking foot problem and progressed to not catching the bobbin thread. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Contributing Member friquant Posted September 6 Contributing Member Report Posted September 6 2 hours ago, NowhereMan01 said: Here is another video of the bobbin area, with me turning the wheel by hand. LMK if any other view might be helpful. Closer, and much slower. 😉 With the machine moving at an even speed (a snail's pace) and never moving in reverse. And with the phone on its side (landscape) instead of up and down. Here is an example of close, slow videos from today: https://leatherworker.net/forum/topic/131845-pfaff-345-issues/ 2 hours ago, AlZilla said: Looking back through this thread, I don't see where you checked the hook timing. Did I miss that part? I agree with ALZilla. From your latest video, the hook is about 150 degrees ahead of where it should be. (Love those timing marks, so visible!) It would be ideal if you could master the art of tripping the safety clutch and then resetting it. Because there is no point in setting the hook timing unless the safety clutch has been re-engaged. While you're making friends with the safety clutch you could also adjust it so that it trips with less torque. That way you won't end up with the belt skipping time again the next time the hook gets bound up. "A" for persistence 🏆 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
AlZilla Posted September 6 Report Posted September 6 If what @CowboyBob told us about the 111W machines holds true, at this point of the needle stroke (all the way down) the point of the hook should be on an imaginary line between the center of the bobbin and the needle plate screw closest to the operator. This one is late or early, depending. In case the viewer can't tell, the point of this hook is right next to the bobbin latch on the opposite side. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members NowhereMan01 Posted September 7 Author Members Report Posted September 7 I will post a new-and-improved video of the bobbin, but I've been trying to figure out the safety clutch, and there does not seem to be much info on this particular style online, and I don't see it discussed in the manual. The 3 attached pictures show the 2 set screws and an end view. I assume that the 3 screws in the end view determine the force needed to disengage. The only picture of these in the manual (Fig. 65) shows them flush with the end, but on my machine they are turned all the way in. If my assumption is correct, I think I'll experiment with different settings to get a better feel for the disengagement/re-engagement. Quote
Contributing Member friquant Posted September 7 Contributing Member Report Posted September 7 I believe you are on the right course. Here is a parts manual for a similar machine that seems helpful to understand the pieces: https://www.manualslib.com/manual/153942/Singer-211a165aa.html?page=15#manual The following page has descriptions of each part. The way I'm interpreting is that each of those three fat screws on the end has a spring underneath it. Together, those three screws through their respective springs provide pressure to the plate that has a detent for the ball. Someone may have screwed those adjusting screws all the way in, not knowing they were adjustment screws. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members NowhereMan01 Posted September 7 Author Members Report Posted September 7 4 hours ago, friquant said: I believe you are on the right course. Here is a parts manual for a similar machine that seems helpful to understand the pieces: https://www.manualslib.com/manual/153942/Singer-211a165aa.html?page=15#manual The following page has descriptions of each part. The way I'm interpreting is that each of those three fat screws on the end has a spring underneath it. Together, those three screws through their respective springs provide pressure to the plate that has a detent for the ball. Someone may have screwed those adjusting screws all the way in, not knowing they were adjustment screws. Thanks! That diagram is very helpful. I loosened the end screws and was able to kick out the safety clutch, and get it to snap back into place (with the clear, distinctive sound that I've seen on YouTube videos). I don't have any feel for how tight it should be set, so I suppose it is safer to leave it at a relatively loose setting for now. The bobbin thread is still not getting picked up, so I'll post a video of that shortly. Quote
