Members Federico Cozzi Posted September 1, 2025 Members Report Posted September 1, 2025 I'm having an issue with my HO HSING G60 servomotor. I'd like to activate the reverse stitching function when I press the heel on my machine's pedal. I went into the motor's configuration menu and enabled the function, but when I press the pedal, nothing happens. The motor only runs in one direction and doesn't reverse. Could someone please help me with this problem? Thanks in advance. Quote
AlZilla Posted September 1, 2025 Report Posted September 1, 2025 If the motor ran backwards, wouldn't the machine run the wrong way and not stitch? I must not be understanding something. Attached is the manual for that motor. SMA-MAN-G-Series-Manual.pdf Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Northmount Posted September 1, 2025 Report Posted September 1, 2025 5 hours ago, Federico Cozzi said: I'm having an issue with my HO HSING G60 servomotor. I'd like to activate the reverse stitching function when I press the heel on my machine's pedal. I went into the motor's configuration menu and enabled the function, but when I press the pedal, nothing happens. The motor only runs in one direction and doesn't reverse. This option is so the motor can be mounted left or right or some other permutation depending on how it is belted, whether the motor is on the left side of the drive belt or right side. If you turn a sewing machine backwards, the hook can't pick up the top thread, and you will likely get into quite a mess. Reverse lever on a sewing machine reverses the action of the feed dog and walking feet, not the hook action. Quote
Contributing Member friquant Posted September 1, 2025 Contributing Member Report Posted September 1, 2025 10 hours ago, Federico Cozzi said: I'd like to activate the reverse stitching function when I press the heel on my machine's pedal. The heel on the machine pedal is typically used to bring the needle up. It still stitches in the forward direction (about half a machine revolution) to bring the needle up. And it only works if you are both using a needle positioner and have stopped with the needle down. That is, you sew along, then release the pedal, and the machine keeps moving until it reaches needle-down, then stops. At that point, you tap the heel and the machine moves (forward) to needle-up. UPDATE Looking at the manual, I see these two options: P-I "Reverse After Pedal Heel Down" P-JJ "Setting of reversing angle" This sounds to me like it's supposed to run the motor in reverse for a finite distance upon heel-tap. I'm not sure what the use case would be. Settings Can you tell us your settings for the following menu items? P-8 : Single signal synchronizer P-I : Reverse after heel pedal down P-J : Setting of reverse angle P-K : Needle up after pedal heel down P-Z : Select machine code Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
