Members ben27 Posted September 8 Members Report Posted September 8 Hi all! I just registered on the forum. I have a Pfaff 145 and just bought a servo motor. The v belt that I had is now too long. it is an optibelt 10x1060. I tried measuring with a string and ended up with 97-99 cm inner diameter. Is there a way to keep using this belt? And if not, what belt do you recommend? Any people with experience with this clutch to servo swap? Thanks a lot! Quote
kgg Posted September 8 Report Posted September 8 2 hours ago, ben27 said: The v belt that I had is now too long. I would go to your local hardware / auto store and see what they have. If the new one is to short / long exchange it for another. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Northmount Posted September 8 Report Posted September 8 9 hours ago, ben27 said: I have a Pfaff 145 and just bought a servo motor. The v belt that I had is now too long. I moved your post to leather sewing machines Quote
Contributing Member friquant Posted September 9 Contributing Member Report Posted September 9 I've been ordering belts from amazon. Here is an example: https://www.amazon.com/uxcell-Classic-Wrapped-Outside-Circumference/dp/B0DR767RWV You can also get them in white: https://www.amazon.com/dp/B0BK1FQHRR Other options include adding a wooden block between the table and the motor (a spacer) so you can use the longer belt. This may require longer bolts though. Or 3D printing a larger machine pulley, which has the added benefit of slowing it down and increasing torque. 12 hours ago, ben27 said: Any people with experience with this clutch to servo swap? Lots of folks have swapped clutch motors to servo motors. Any particular questions you have about the swap? Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members ben27 Posted September 12 Author Members Report Posted September 12 Dear all, thank you for your answers. I ended up ordering a shorter V belt (97,5 cm) from optibelt. So no extra block to lower the servo. This was enough. It works a treat now! Quote
