Members ThisIsMyFirstRodeo Posted October 6, 2025 Members Report Posted October 6, 2025 Hey all, Has anyone experienced any issues with NFO and topcoats, whether NFO is applied before or after? Products used: Tandy’s econo veg tan shoulder, dyed with EcoFlo deep violet leather dye, Dr. Jackson’s pure NFO, EcoFlo super sheen) Backstory: After becoming accustomed to the juicy vibrancy of Angelus’s purple leather dye, I’m unimpressed with the EcoFlo, in depth of color as well as polished sheen (I did 3 coats total). Finally got my hands on some NFO (oil not compound), and figured I’d give it a try to see if it helped either color or sheen. Then it caught water spray while I was working another piece, and bled onto my hands and the paper towel I was using to dry it. And remembered that it’s water-based and I hadn’t sealed it yet so I grabbed the super sheen. No matter how many coats ive tried, it simply runs off. Deciding that the issue might be the NFO, I used some saddle soap to try to remove it, let it sit a couple minutes, and rinsed off before trying again. Super sheen still just rolled off. And that brings us up to now. I really don’t want to deal with unhappy wife or customers dealing with stained skin and clothes, so I’m looking for a solution. Thoughts? TIA, AZR Quote
kgg Posted October 6, 2025 Report Posted October 6, 2025 1 hour ago, ThisIsMyFirstRodeo said: Tandy’s econo veg tan shoulder, dyed with EcoFlo deep violet leather dye, Dr. Jackson’s pure NFO, EcoFlo super sheen 1 hour ago, ThisIsMyFirstRodeo said: I really don’t want to deal with unhappy wife or customers dealing with stained skin and clothes, so I’m looking for a solution. Thoughts? I have used Angelus dye and it is an excellent product just to expensive to use on a regular basis. I mostly use Fiebing's dye with good results. The econo leathers I think tend to be a bit drier then the more expensive ones. I also don't use NFO oil for many reasons and prefer JoJoba oil as it is the closest you can get to sperm whale oil. I oil first before applying any dye and let sit for 24 hours to soak in and spread out opening the fibres of the leather. This link to a topic maybe of some help or give you some ideas on your dying process. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members ThisIsMyFirstRodeo Posted October 6, 2025 Author Members Report Posted October 6, 2025 3 hours ago, kgg said: I have used Angelus dye and it is an excellent product just to expensive to use on a regular basis. I mostly use Fiebing's dye with good results. The econo leathers I think tend to be a bit drier then the more expensive ones. I also don't use NFO oil for many reasons and prefer JoJoba oil as it is the closest you can get to sperm whale oil. I oil first before applying any dye and let sit for 24 hours to soak in and spread out opening the fibres of the leather. This link to a topic maybe of some help or give you some ideas on your dying process. kgg Thank you. Fiebings is definitely my go-to as well. And the Angelus is awesome, but it also feels like busting out the Pappy Van Winkle 9yr on a weeknight to me, if you know what I mean. I’ll give your method a try and see how it works for me. — AZR Quote
kgg Posted October 6, 2025 Report Posted October 6, 2025 37 minutes ago, ThisIsMyFirstRodeo said: I’ll give your method a try and see how it works for me. Hope it helps and I would be interested in knowing how it works out. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Dwight Posted October 6, 2025 Members Report Posted October 6, 2025 (edited) I've been messing with leather for 25+ years so far . . . NEVER have had any thing I made give me problems with Resolene . . . it goes on . . . stays on . . . and works. I was really . . . REALLY . . . mad at a belt I made one time using USMC black . . . I think I could have wire brushed that thing and black would still have rubbed off. Grabbed the Resolene . . . 2 light coats . . . END of problem. Try it . . . you have nothing to lose at this point . . . if you've never used it . . . make sure to dilute it . . . 50 / 50 Resolene and tap water. Stir well and put on with a bristle paint brush (I use the little cheap 1 inch wide throw away ones . . . rinse the resolene out of it . . . use it for months) . . . You kind of slop it on to start with . . . then give it the up/down . . . left / right . . . right angle . . . left angle . . . put enough on that serious brushing will cause a bit of foam to come up . . . then brush it until all the bubbles are busted . . . that is one coat. Give it 20 minutes to rest and add a second coat . . . and you should be fixed all and good. May God bless, Dwight Edited October 6, 2025 by Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members ThisIsMyFirstRodeo Posted October 6, 2025 Author Members Report Posted October 6, 2025 1 hour ago, Dwight said: I've been messing with leather for 25+ years so far . . . NEVER have had any thing I made give me problems with Resolene . . . it goes on . . . stays on . . . and works. I was really . . . REALLY . . . mad at a belt I made one time using USMC black . . . I think I could have wire brushed that thing and black would still have rubbed off. Grabbed the Resolene . . . 2 light coats . . . END of problem. Try it . . . you have nothing to lose at this point . . . if you've never used it . . . make sure to dilute it . . . 50 / 50 Resolene and tap water. Stir well and put on with a bristle paint brush (I use the little cheap 1 inch wide throw away ones . . . rinse the resolene out of it . . . use it for months) . . . You kind of slop it on to start with . . . then give it the up/down . . . left / right . . . right angle . . . left angle . . . put enough on that serious brushing will cause a bit of foam to come up . . . then brush it until all the bubbles are busted . . . that is one coat. Give it 20 minutes to rest and add a second coat . . . and you should be fixed all and good. May God bless, Dwight I should pick some Resolene up on my next Tandy run. I actually just made a bag using USMC black for the straps and billets, but I gave them a healthy coat of ProResist. Hopefully it’ll do the trick… — AZR Quote
wizard of tragacanth Posted October 7, 2025 Report Posted October 7, 2025 Use Tandy Pro Dye, there is virtually no rub-off. USMC Black... nightmare... but it is black. The Pro Black has a bluish, purplish sheen at certain angles, or so I have found. I still use it though. Quote Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
Members ThisIsMyFirstRodeo Posted October 7, 2025 Author Members Report Posted October 7, 2025 13 hours ago, wizard of tragacanth said: Use Tandy Pro Dye, there is virtually no rub-off. USMC Black... nightmare... but it is black. The Pro Black has a bluish, purplish sheen at certain angles, or so I have found. I still use it though. I’m assuming that you’re also familiar with the Fiebings Pro black. What’s your preference? AZR Quote
Members ThisIsMyFirstRodeo Posted October 7, 2025 Author Members Report Posted October 7, 2025 (edited) For those curious, the Pro Resist seems to have sealed. KGG — I oiled a piece last night. This morning, the color of the leather is just slightly little darker, but even across the piece. Seems to be a perfect blank canvas. Usually I tool before I dye, but today I plan to dye and tool tomorrow, along with a piece I didn’t oil, and we’ll see how much dye bleeds as I case it… AZR Edited October 7, 2025 by ThisIsMyFirstRodeo Extra detail Quote
wizard of tragacanth Posted October 8, 2025 Report Posted October 8, 2025 On 10/7/2025 at 8:00 AM, ThisIsMyFirstRodeo said: I’m assuming that you’re also familiar with the Fiebings Pro black. What’s your preference? AZR Sorry about the confusion. I am getting rather feeble minded, lately. Yes, Fiebings Pro Black is what I meant. I wouldn't use anything else. Nick Quote Wisdom from an old Missouri farmer, my Grandpa: If it's not sharp, it's not a knife.
