Members BDLS Posted November 3 Members Report Posted November 3 I bought a Chinese servo motor for my 111w155. It came with a 75mm pulley. I need a 45mm. This issue is the bore on the pulley is tapered. It’s 9mm at the nut side of the pulley and gets larger towards the motor. I can’t find a source for this pulley. Any help? Quote
Members Constabulary Posted November 3 Members Report Posted November 3 (edited) What country do you come from? College Sewing and Trojan Sewing in the UK have tapered bore pulleys. I cannot reach the College Sewing website atm seems it is down for maintenance or so https://www.trojansewing.co.uk/?s=tapered&post_type=product&type_aws=true Edited November 3 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Northmount Posted November 3 Report Posted November 3 7 hours ago, Constabulary said: What country do you come from? IP says Richardson, Texas, 75080 (USA) 13 hours ago, BDLS said: I bought a Chinese servo motor for my 111w155. It came with a 75mm pulley. I need a 45mm. This issue is the bore on the pulley is tapered. It’s 9mm at the nut side of the pulley and gets larger towards the motor. I can’t find a source for this pulley. Any help? It is a good idea to include your location in your profile so you get answers that may be more applicable to your area and needs. Quote
Members Constabulary Posted November 3 Members Report Posted November 3 College Sewing is back: https://www.college-sewing.co.uk/catalogsearch/result/index/?cat=3&q=tapered+bore&p=1 but I´m sure most sewing machine dealers in the US can get you tapered bore pulley as well. Maybe worth checking with Toledo Sewing Machines Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Contributing Member friquant Posted November 4 Contributing Member Report Posted November 4 I posted about this here: Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members BDLS Posted November 5 Author Members Report Posted November 5 Im in Texas. I did manage to get the manufacture to add a 50mm pulley to Amazon. So I have one on the way. Quote
