Members TheMortgageGuy Posted 9 hours ago Members Report Posted 9 hours ago Hello group experts. I moved in July and the movers broke the take up arm on my Juki Lu563. I had a local company repair the machine paid for by the moving company. $730 repair cost. I got the machine back and it doesn’t seem to be sewing properly. hook is too close to the needle, hitting it going forward and appears to be slightly off going in reverse . I spent hours in the past getting this machine to perform flawlessly using help from this forum. Unfortunately the arm that was installed appears to be shorter and does not have the same lift and extension as the original arm did attached is a pic of the new arm installed on the machine I am sure that the old arm at least extended to the front edge of the flange guard to the left of the arm and the new arm does not extend out that far kind of like a Juki lu562 arm and upgrading to a 563 arm when doing a big bobbin conversion am I right ? Is this the wrong arm? thank you richard richardf1969@gmail dot com 9 05 73 00 844 text Quote Juki Lu563 with Servo, Singer 20U with Enduro SM 645B, Pfaff 142-6/2. BL, PFAFF 335-H3-6/01-900/52-BLN
AlZilla Posted 2 hours ago Report Posted 2 hours ago Here's a pic of the same machine right here in this very forum. I think it looks like a longer tension arm. I'd send pics to whoever "fixed" it and ask them. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
CowboyBob Posted 1 hour ago Report Posted 1 hour ago Yes,it looks like a 562 take up lever the 563 is longer.How does it sew?I doubt it will make much difference. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
