Members Dan_IN_MN Posted November 10 Author Members Report Posted November 10 It's together and sewing! Thank you!! Quote
Northmount Posted November 10 Report Posted November 10 13 hours ago, Dan_IN_MN said: It's together and sewing! Pictures are too small to see any detail. Resize the original pics to 800 pixels in the longest dimension and we should be good to go with lots of detail. Quote
Members Dan_IN_MN Posted November 11 Author Members Report Posted November 11 It's all good. Not much to see. Cleaned up the shaft and the bore it goes in. Put things back together, threaded the machine and sown a crooked line of stitches . Quote
Contributing Member friquant Posted November 11 Contributing Member Report Posted November 11 18 hours ago, Dan_IN_MN said: Cleaned up the shaft and the bore it goes in. You may want to figure out where you are expected to oil that shaft 😉 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
AlZilla Posted November 12 Report Posted November 12 I couldn't picture that shaft until I went back and looked at one of mine. Now I see it runs in the lower part of the arm! Another lesson learned for me. I, too, will have to double check where it gets oiled. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members Dan_IN_MN Posted November 18 Author Members Report Posted November 18 On 11/11/2025 at 3:15 PM, friquant said: You may want to figure out where you are expected to oil that shaft 😉 You're absolutely correct! I downloaded an oiling guide! On 11/11/2025 at 6:05 PM, AlZilla said: I couldn't picture that shaft until I went back and looked at one of mine. Now I see it runs in the lower part of the arm! Another lesson learned for me. I, too, will have to double check where it gets oiled. Glad I helped! Quote
