Members Zonker62 Posted 36 minutes ago Members Report Posted 36 minutes ago Hi Everyone, My Seiko STW-8B is doing OK for Bimini tops, doghouses, lazy bags but sometimes, the thread coming from the bobbin gets out of the slit , always when starting a job and now I know that after 2'', if it's OK then I can continue, but it's boring.. I have the occasion of getting a Mitsubishi DU-105, How would you compare the Seiko STw-8B, to the M DU-105 and an adler 167-63 (simple, a worhorse, although drop feed and needle feed only, a great machine)? In terms of - stitch length -ruggedeness - parts availability Thanks a lot for your answers, it\s a very interesting community here! Best Xavier Quote
Northmount Posted 24 minutes ago Report Posted 24 minutes ago 9 minutes ago, Zonker62 said: My Seiko STW-8B is doing OK for Bimini tops, doghouses, lazy bags but sometimes, the thread coming from the bobbin gets out of the slit , always when starting a job and now I know that after 2'', if it's OK then I can continue, but it's boring.. I have the occasion of getting a Mitsubishi DU-105, I moved your post to Leather Sewing Machines. Help wanted is like news paper classifieds where you want some one to work for you. Also every pot there requires moderator approval before members can see it. You'll more help in this forum. Quote
kgg Posted 17 minutes ago Report Posted 17 minutes ago 18 minutes ago, Zonker62 said: My Seiko STW-8B is doing OK for Bimini tops, doghouses, lazy bags but sometimes, the thread coming from the bobbin gets out of the slit , always when starting a job and now I know that after 2'', if it's OK then I can continue, but it's boring.. Could you post a few photo's of your top thread from the spool to the eye of the needle. I think this is a fairly easy problem to solve. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Zonker62 Posted 14 minutes ago Author Members Report Posted 14 minutes ago Thanks Northmount! Cool! Quote
Members Zonker62 Posted 10 minutes ago Author Members Report Posted 10 minutes ago @KGG Thanks, it's night time now a comin' but I'll do that tomorrow. If I understand well, you want a close up of the thread going from the spool to the needle while the hook is passing by? I'll try to make some shots but it won't be easy.. You gave me a hint, needle bar height? Will post tomorrow... Have a good one! Quote
