Contributing Member friquant Posted December 11, 2025 Contributing Member Report Posted December 11, 2025 How about diesel or other penetrating oil on the stud? How about tapping the tip of the stud with a long steel rod and a light hammer? Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
AlZilla Posted December 11, 2025 Report Posted December 11, 2025 1 hour ago, Ghoust6 said: . I was looking for a hidden super small bolt in the fork holding it so tightly. As I said I was trying everything and no luck. If someone ever Yeah, this is the challenge. That 18-2 isn't one of the common machines that everyone's seen a hundred times. I'm hoping someone will check in who's done that job. Maybe @Wizcrafts knows something? Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Contributing Member friquant Posted December 11, 2025 Contributing Member Report Posted December 11, 2025 The parts list for my Singer 31-15 shows more of these parts together as a group, which might be useful. Have you tried removing the stitch length adjustment screw (818D in this screenshot) ? With that removed maybe the whole cluster will slide out toward the camera.. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Contributing Member friquant Posted December 12, 2025 Contributing Member Report Posted December 12, 2025 Here's a video where someone removes that fork from a Singer 31k15: Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
Members Constabulary Posted December 12, 2025 Members Report Posted December 12, 2025 (edited) I think the fork is attached to part no 3033 (feed fork connection link) from the rear with a screw (the one which thread you see on your last picture) and the part 3033 is attached to the 6459 (feed regulator = Stitch length adjuster) and to the machine body with a screw and I think this is screw the read arrow is pointing to (see picture below). So I think you have to remove this screw first. The rest is trial and error. I recall it was similar on my Singer 45D91 back then. Look at these parts from the rear side, you should see the parts through the hole. Move the stitch length lever up and down and I think you will notice what I have described. EDIT: I just noticed the video - it shows what I mean. Edited December 12, 2025 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Ghoust6 Posted December 12, 2025 Author Members Report Posted December 12, 2025 Constabulary the screw you are pointing is 375 i think and its locked by 1518 nut so Im unable to unscrew it. First I would have to unscre the nut but there is no way i can reach it. I think that lowering the fork or position it in a place so i can unscrew 58 screw will do the trick. Bonus for everyone mix of strong alcohol 45% + naphtha 45% + sewing oil 10% will do magic with old rusty screws. I think the only stronger thing than that is hot naphtha. Also that mixture won't destroy shelac or paint. Ofcourse it's just for losen everything and after that you must use sewing oil only. Friquant thank you so much I think you might just solve the problem but when I try I will say. Quote
Members Ghoust6 Posted December 18, 2025 Author Members Report Posted December 18, 2025 Problem solved friquant is right. Thank you all!! Quote
Members rmdorman Posted December 23, 2025 Members Report Posted December 23, 2025 Hah did you send this to Florida? I just received a 18U222 from Poland and think this machine or its cousin might be mine now Is a neat old machine. I have seen several Japanese bespoke shoemakers prefer them as they allow you to sew right along a top edge with the work supported, and I figured I would see if I could put this one back into service for the same I was going to ask if anyone knew if parts from the more common right-hand cylinder arm light leather machines like class 17 might be interchangeable eg needle plate, accessory work table. ISMACS suggests they are mirror copies. Quote
Contributing Member friquant Posted December 23, 2025 Contributing Member Report Posted December 23, 2025 9 hours ago, rmdorman said: I was going to ask if anyone knew if parts from the more common right-hand cylinder arm light leather machines like class 17 might be interchangeable eg needle plate, accessory work table. ISMACS suggests they are mirror copies. You'll have better luck if you start a new topic 😉 Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
