I am in need of a gear for my 29k machine. It is the one that goes inside to drive it with the wheel on the front.  The hub is there. but a previous owner took out the shaft and gear.
Has anyone found a gear that size on Amazon or anywhere else?  Or made a gear.  The singer number is 81869. I can make the shaft and adapt the gear if needed it just needs to be right tooth number and diameter.
I think I mentioned somewhere that I may have one.... Will check later.... heading to work now...
Thank you.  Please tell me if you have anything.
