Members WalterF Posted 2 hours ago Members Report Posted 2 hours ago Wanted to do some petal lifting, making the leather look more 3d by stretching up certain sections. Mine are in NC, didn't want to buy an expensive set. For under 20 dollars and an hours work here we are. Pretty happy. The items, Stainless rods, handles, super glue, I found a set of stainless rods 1.5mm to 8mm x 60mm long these were 8.99, the handles are file handles got 12, 6 large not used and 6 small, 6.99. Put the rods in the handles, for the small ones wrapped painters tape around the top for a snug fit then used some super glue down the hole to fix them. The grinding to shape can be done many ways bench grinder, files, dremmels, the angle isn't precise we are after a cutting edge. I like the angle around 45 degrees with the heel radiused. Used a course grinder to get shape and then went to a finer belt grinder. Then used sharpening stones to clean up the scratches, finished with 2000 on the stones and then used a strop with polishing compound to bring a mirror polish, we want it to be razor sharp at the tip as it is a cutting tool.. Quote
