Hi everyone, first of all I want to say a huge thank you to everyone on this forum who helped me with a lot of problems. It's really great  to be here and be part of the community. Now to my  help, I have a customer/frind with a Pfaff 2545 basic and he claims that there is a known problem with the machine that the screw that holds the needle bar is not doing its job well enough and as a result of course the machine goes out of time.
So I wanted to know if this is true? Has anyone else encountered this problem or is it really known? And also, is there a known solution for this??
I sew the machine but at that time he didn’t told me about any problem, and he gives me the original motor of the machine because it was to fast and he didn’t found how to lower the speed so he bought cheep brushless motor from Ali express
10xs
I´d say this new fancy Pfaff machine range is not wide spread already. I doubt there is much experience with this type of machine yet. But why should a top class manufacturer like Pfaff have needle bar issues? Well, you never know but I seriously doubt this cause they for sure have experience from the older models and why should a simple part like a needle bar cause issues? If there was / is a known issue then your Pfaff dealer should know about it and should provide a replacement.
Hi thank you
Dealer don’t know about this noting
and as I see no one here knows about it also so I think it’s nonsense so I need to go there and check for myself
Iam  very curious to know what's really going on there, it's just that he lives really far from me, but there's no way I'll have to see it. Thank you very much.
To me I think it probably has more to do to a individual machine problem then a manufacturing problem as a result of wear, over‑tightening/under‑tightening, or a damaged screw or clamp.
If you are able to check the machine inspect the needle‑bar clamp and screw for wear and or other damage like a buckle needle bar, stripped screw / clamp and check that it is tightened properly and then if all is good re‑time the hook‑to‑needle as per the service manual, if not replace damaged parts then re-time.
The PFAFF 2545 is manufactured in the P F A F F Industriesysteme und Maschinen GmbH factory in Taicang, near Shanghai, China.
My experience:
The Juki DU-1181n is a decent walking foot machine but the quality is nowhere near that of my Juki DNU-1541S. The difference is the 1181N is made in China and the 1541S is made in Japan.
kgg
Thanks tomorrow I'm going there to figure out what the problem really is, I'll try to remember to take some pictures
IMG_1402.jpeg.e3df1a0d32ec7552d2f29860fd586f63.jpegHe replaced the original screw with this one, and now it really slips very quickly
I guess that's the one
Looks kind of normal screw, you can always but another one.
It's the big rocker that is holding the needle bar, this screw is  used just to tighten it. The only problem with is a  screw could be un-tightening during the use, that you can probably solve with Loctite. I would be careful not to damage the thread inside the rocker. That is for sure much more expensive to change.
I trying to find new rocker to order and new screw
for sure the thread is damaged in there, so will replace for new
thank you
What makes you say the threads are damaged?
If they will still tighten up, I would clean the threads and reassemble using medium strength threadlocker. (Coarse threads like this are likely to back out without threadlocker)
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
