Members Monticore Posted January 20, 2009 Members Report Posted January 20, 2009 (edited) i recently got some leather and i find not matter how light i do my saddle stich i get crinkling/crimping of the edges. which then gives my a undulating edge. i manage to sand it down a bit but i can still feel it when i run my fingers on the edge. i am using a stitching pony. with thonging chisels to punch my holes . would i guess less crinkling with overstitch wheel/awl combo? any tips much appreciated. cory Edited January 20, 2009 by Monticore Quote
tashabear Posted January 20, 2009 Report Posted January 20, 2009 Are you cutting a stitching groove before you punch your holes? Quote
Members tonyc1 Posted January 20, 2009 Members Report Posted January 20, 2009 Try using an Awl. Quote
Contributing Member UKRay Posted January 20, 2009 Contributing Member Report Posted January 20, 2009 (edited) Monticore, I'm assuming you could be talking about the 'face' of the leather - in other words not the cut edge - The crinkling you talk about is a pretty normal occurrence and easily rectified. When you have finished your stitching just wet the leather slightly (do not dunk!) and lightly tap the stitches (and the edge) edge down flat with a flat faced steel hammer (a nicely polished, very slightly convex shoemakers/harness maker's hammer is ideal). This will bed your stitches into the leather and if you have used a groover to cut a channel for your stitching it will sink the thread into the channel nicely. I was taught to hammer stitching flat as a general thing when making working harness as it cuts down the chafe and wear and makes the kit last longer. Getting rid of the wrinklies was a welcome by-product! If you are getting a crinkle on the cut edge - like a cookie cutter effect - then you may be slightly too close to the edge when you punch your stitch holes or you may need to explore other ways of making your holes as Tasha and Tony have suggested. One last thing - if you haul up your thread really tight, you can create ruckles in the leather too. Your stitching needs to be firm and tight enough to make a good job but not excessively tight so the work is spoiled. Ray Edited January 20, 2009 by UKRay Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members Monticore Posted January 20, 2009 Author Members Report Posted January 20, 2009 Are you cutting a stitching groove before you punch your holes? i did use a groover before stitching but i did not cut very deep. i will try a little deeper next time see if it helps . i am going to try a awl next strap but my tandy awl tends to make too big a hole for my stitch . cory Quote
Ambassador Luke Hatley Posted January 20, 2009 Ambassador Report Posted January 20, 2009 (edited) what thickness of leather are you hand sewing ? and how far apart are you punching your stiching holes? Edited January 20, 2009 by Luke Hatley Quote Luke
Dale Posted January 20, 2009 Report Posted January 20, 2009 I wonder if you've got a piece of leather with a loose grain, or you're using the belly area. If that's the case, try a different area of the hide (or a different hide altogether). If the leather isn't firm enough, I'm not sure there's any technique that will compensate for it. Quote Dale Hietala www.moonlightartstudio.com
Members Monticore Posted January 20, 2009 Author Members Report Posted January 20, 2009 what thickness of leather are you hand sewing ?and how far apart are you punching your stiching holes? it is 5-5.5 oz oil tanned , folded over to make a 5mm strap, it might be from the belly area , i will try another area for my next work. cory Quote
Members Monticore Posted January 21, 2009 Author Members Report Posted January 21, 2009 here are some pics of my test strap , might be hard to tell but there is a bit of a wavyness to the edge. after the pics i also noticed i probably need to dye my groove before stitching cory Quote
Members tonyc1 Posted January 21, 2009 Members Report Posted January 21, 2009 What size thread is that you have used? It seems very coarse ! How wide is the strap? Tony. Quote
