Hi all.
my tack shop where i get my work from has a circle Y "team penner" with a loose leather cover over the horn cap. they would like me to try and tighen/fix it, but im thinking it probably needs to be replaced. the stitching on the far side is loose/worn thru (a couple stitches ony) and the leather horn cap is a sloppy fit. the horn looks like an aluminum casting and horn shaft cover looks okay.
is there something i can do or is this something that needs to redone?
Im thinking i could glue the leather to the horn, but its still going to be loose and in the end will more then likely work loose again. my thinking is that it worked loose from using it as a handle to PULL the rider into the seat.
btw, i mostly do strap goods repair and make belts/holsters.
TIA
Riding is a partnership. The horse lends you his strength, speed and grace, which are greater then yours. For your part you give him your guidance, intelligence and understanding, which are greater then his. Togeather you can achieve a richness that alone neither can.
- Lucy Rees, The Horse's Mind
  • Ambassador
got a photo. it would help.
Luke
thanks for the offer.
currently my mac is having issues w/posting pics.
i just told the owner to have it repaired by someone else.
