Members MsDragonfly Posted February 11, 2009 Members Report Posted February 11, 2009 Guys, I just got the red hand press and it's dyes for the jiffy rivets from tandy to help with setting my rivets more consistently. One problem....now instructions!! I don't know what dye goes on the top and what one on the bottom, nor do I know how to adjust the setting depth of the handle and ....well you get the picture. Anyone use this machine and can you help me figure out the proper set-up of it. Maybe a picture tutorial? Thanks in advance for the help.***Lisa Quote
Members $$hobby Posted February 13, 2009 Members Report Posted February 13, 2009 Guys, I just got the red hand press and it's dyes for the jiffy rivets from tandy to help with setting my rivets more consistently. One problem....now instructions!! I don't know what dye goes on the top and what one on the bottom, nor do I know how to adjust the setting depth of the handle and ....well you get the picture. Anyone use this machine and can you help me figure out the proper set-up of it. Maybe a picture tutorial? Thanks in advance for the help.***Lisa Since you dont say which model you have or you dont have a pic i will have to wing it. For adjustment, if you look behind the handle where it pivots, there maybe a bolt that the handle stops agains when you press down on the handle. That is the adjustment. as far as the dies and which goes where, i believe it doesnt matter. it would depend on how you want to apply the snaps. there should be a die to fit the top and a die to fit the bottom. i dont see any problem with setting the snap upside down if needed. Quote Riding is a partnership. The horse lends you his strength, speed and grace, which are greater then yours. For your part you give him your guidance, intelligence and understanding, which are greater then his. Togeather you can achieve a richness that alone neither can. - Lucy Rees, The Horse's Mind
Members MsDragonfly Posted February 15, 2009 Author Members Report Posted February 15, 2009 Since you dont say which model you have or you dont have a pic i will have to wing it.For adjustment, if you look behind the handle where it pivots, there maybe a bolt that the handle stops agains when you press down on the handle. That is the adjustment. as far as the dies and which goes where, i believe it doesnt matter. it would depend on how you want to apply the snaps. there should be a die to fit the top and a die to fit the bottom. i dont see any problem with setting the snap upside down if needed. Yep thats the one I got and I figured it out. Works awesome with the OTB jiffy rivets. Perfect strong hold every time with a flawless appearance. Best machine i got so far. heck on hand setting them anymore. I'll never go back. Thanks***Lisa Quote
Members TomBanwell Posted February 15, 2009 Members Report Posted February 15, 2009 I have the same tool, and I love it. I don't think it matters which is up and which is down. I just press it all the way down. No need to adjust the depth. Quote
