Members TinyL Posted March 21, 2009 Members Report Posted March 21, 2009 I need to take satin sheen off and get rid of the streaking from eco flow dye. I know i need a deglazer but is there anything else i could buy from a local store ( hardware or otherwise) to take the satin sheen off? Otherwise i'll have to order it online and wait for it and i'd rather not. Thanks for the help! Quote
Contributing Member UKRay Posted March 21, 2009 Contributing Member Report Posted March 21, 2009 I generally find that methylated spirits will shift most things and it is available from most hardware stores... I'm not sure if it has another name in the US but that is what I would use... Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members CitizenKate Posted March 21, 2009 Members Report Posted March 21, 2009 I need to take satin sheen off and get rid of the streaking from eco flow dye. I know i need a deglazer but is there anything else i could buy from a local store ( hardware or otherwise) to take the satin sheen off? Otherwise i'll have to order it online and wait for it and i'd rather not.Thanks for the help! I've been able to remove it with just water. Kate Quote
Contributing Member UKRay Posted March 21, 2009 Contributing Member Report Posted March 21, 2009 Listen to Kate - she knows waaay more than me! R. Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members CitizenKate Posted March 21, 2009 Members Report Posted March 21, 2009 ... which is why you never want to use an acrylic finish on anything that might be used outdoors. I learned that the hard way! Kate Quote
Members TinyL Posted March 21, 2009 Author Members Report Posted March 21, 2009 thanks guys. what if there was atom wax over the satin sheen. would denatured alcohol work? if i used that then do i need to do anything to the leather before i reapply the dye and then seal? thanks in advance TinyL Quote
Members ryano Posted March 21, 2009 Members Report Posted March 21, 2009 Denatured alcohol is the same thing as deglazer. They have it at ace and w.m. Quote
Members Saddlebag Posted March 22, 2009 Members Report Posted March 22, 2009 I've often used acetone to remove the shine from leather in preparing it for dying. I believe that is what Deglazer is. Quote
Members CitizenKate Posted March 22, 2009 Members Report Posted March 22, 2009 Deglazer will remove a wax finish. According to the label, it contains ethyl acetate, which is not the same as denatured alcohol. Deglazer is less harmful to your leather than denatured alcohol, and is not as toxic. Acetone is also a different substance than ethyl acetate, but is used for many of the same things. One interesting thing I came across on Wikipedia was that ethyl acetate is also used in nail polish remover, and sure enough, that's exactly what deglazer smells like. If you're looking for something you can get locally, maybe nail polish remover will work. Kate PS: Be sure to test it first! Quote
Contributing Member barra Posted March 22, 2009 Contributing Member Report Posted March 22, 2009 The methylated spirits (Metho) that UKRAY is referring to is called denatured alcohol in the US. Barra Quote "If You're not behind the Troops, please feel free to stand in front of them"
