Members jettrash Posted April 14, 2009 Members Report Posted April 14, 2009 Hey folks. I really like the Craftool Backgrounder A104-2, or 66104-22 depending on which name you go by. But I would like one that is even smaller and I cant find anyone that sells a smaller version of that tool. I've read a few threads here about customizing Craftools and I'd like to try it. One problem is I dont have access to a grinder. Is this something that is possible to do without power tools? And if it is what would I need to do it? Or should I take one to some tool & die place and have them do it? Thanks. Quote
Members Tina Posted April 14, 2009 Members Report Posted April 14, 2009 (edited) jettrash said: Hey folks.I really like the Craftool Backgrounder A104-2, or 66104-22 depending on which name you go by. But I would like one that is even smaller and I cant find anyone that sells a smaller version of that tool. I've read a few threads here about customizing Craftools and I'd like to try it. One problem is I dont have access to a grinder. Is this something that is possible to do without power tools? And if it is what would I need to do it? Or should I take one to some tool & die place and have them do it? Thanks. Hi, I have modified the same tool, I was just using my dremmel with the sander to make it smaller, finished of by using a 600 grit sandpaper by hand... "Easy as apple pie" :-) Edited April 14, 2009 by Tina Quote "He who works with his hands is a laborer. He who works with his hands, and his head is a craftsman. He who works with his hands, and his head, and his heart, is An Artist" http://vildkorpens-laderlya.deviantart.com http://tupali.deviantart.com/
Mike Craw Posted April 14, 2009 Report Posted April 14, 2009 In a class in Asheville, NC that I took with ArtS a couple of weeks ago, Pete Gorrell taught us how to modify some Craftools. He just used a fine milled file and some 600 and 1000 or 1200 emory cloth that you can get from auto body shops. If Art and I can do it, you know it ain't brain surgery!! Mike P.S. Sorry Art, I mean if I can do it... Tina said: Hi,I have modified the same tool, I'm was just using my dremmel with the sander to make it smaller, finished of by using a 600 grit sandpaper by hand... "Easy as apple pie" :-) Quote My choice early in life was either to be a piano-player in a whorehouse or a politician. And to tell the truth, there's hardly any difference. Harry S. Truman
BearMan Posted April 14, 2009 Report Posted April 14, 2009 Hi, Yep,,, that's the best thing to do, just like what Tina said. The only thing I'd add, is to burn off the chrome platting also. It's easy to do, & it makes the impressions quite a bit crisper. Ed Quote Ed the"BearMan" polarb1717@aol.com Beary: BearMauls@yahoo.com http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
Members jettrash Posted April 14, 2009 Author Members Report Posted April 14, 2009 Can you burn it off with a lighter? Quote
Members jettrash Posted April 15, 2009 Author Members Report Posted April 15, 2009 The Dremel Tool worked great for grinding it down. Thanks a lot for the advice. Quote
mendedbowl Posted November 8, 2010 Report Posted November 8, 2010 On 4/14/2009 at 9:30 PM, BearMan said: Hi, Yep,,, that's the best thing to do, just like what Tina said. The only thing I'd add, is to burn off the chrome platting also. It's easy to do, & it makes the impressions quite a bit crisper. Ed what's the safest and best way to remove the chrome platting? thanks, ken Quote
BearMan Posted November 8, 2010 Report Posted November 8, 2010 Hi Ken, Just a regular propane torch works fine. Just be careful to not get it too hot. Once you see the it's getting hot, just rub it with a fine wire brush, & the chrome will come right off. One point you need to be wary of,,, some of the newer tools, are made out of "sintered" metal, which melts at a very low temp. Sintered metal is made by compressing metal powder. So if you are going to do adapt a tool,,, it should be an older one. Ed Quote Ed the"BearMan" polarb1717@aol.com Beary: BearMauls@yahoo.com http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
Members BIGGUNDOCTOR Posted November 8, 2010 Members Report Posted November 8, 2010 If you are going to remove the chrome with heat , do it outside in a well ventilated area. Chrome gives off some nasty fumes. Do not breath them. Quote You laugh at me because I am different. I laugh at you because you are all the same.
mendedbowl Posted November 8, 2010 Report Posted November 8, 2010 On 11/8/2010 at 3:29 AM, BearMan said: Hi Ken, Just a regular propane torch works fine. Just be careful to not get it too hot. Once you see the it's getting hot, just rub it with a fine wire brush, & the chrome will come right off. One point you need to be wary of,,, some of the newer tools, are made out of "sintered" metal, which melts at a very low temp. Sintered metal is made by compressing metal powder. So if you are going to do adapt a tool,,, it should be an older one. Ed Hi Ed, thank you for the for the quick answer. I've got the torch, the wire brush, and a bunch of old craftools collected off of ebay that i'm looking forward to cleaning up. and thanks for the warning Biggundoctor, i'll be sure to do it outside with adult supervision (another way of saying my son will be standing by with the garden hose, ready to put me out) thanks, ken Quote
