Members canemaker Posted April 18, 2009 Members Report Posted April 18, 2009 I live in a very popular area for deer hunting. so needless to say I have access to lots of deerskins. I have decided to learn how to Tan my own leather and take up some of my free time. Right now I have 3 salt cured skins and I have read dozens of articles and methods. YES I have become confused. My question is: What is the best process to obtain quality leather (not Buckskin) for multiple projects I understand brain tanning produces great buckskin and leather but playing with brains just doesn't excite me. yuk Tanning kits tanning solutions in a bottle veg tanning (does this work on deerskin it feels pretty thin) Potash alum aluminum sulfate bating pickling neutralizing help I'm dizzzy Quote
Members Jim Posted April 19, 2009 Members Report Posted April 19, 2009 Well Canemaker, I've tanned a deer hide or two and there is another way besides mushin' up them brains. All you need is a quick trip to the grcery store and buy two cans of Alum. Yep. it's a pickling angent. Now, you can stretch the wet hide in a rack, let dry, and then scrape the hair off while it's still "green" or soak it hair and all. Either works as well as the other. The only difference is that with the hair scraped off first, you only need to soak it in the Alum and water solution for about two days, stiring it a couple of times a day. Then remove the hide, rinse well, and proceed with the drying and stretching, or softening process. The again, if you leave the hair on you will need to soak it for about four days or untill the hair begins to slip off. At that point you can remove the hair with a wet rag. The Alum will loosen the roots and the hair just comes right off. I learned that by accident when I was tanning a Hair-on Hide and left it in the Alum Solution too long. Then, you can go ahead and do the drying and softening. Have fun Quote
Members canemaker Posted April 19, 2009 Author Members Report Posted April 19, 2009 Well Canemaker, I've tanned a deer hide or two and there is another way besides mushin' up them brains. All you need is a quick trip to the grcery store and buy two cans of Alum. Yep. it's a pickling angent.Now, you can stretch the wet hide in a rack, let dry, and then scrape the hair off while it's still "green" or soak it hair and all. Either works as well as the other. The only difference is that with the hair scraped off first, you only need to soak it in the Alum and water solution for about two days, stiring it a couple of times a day. Then remove the hide, rinse well, and proceed with the drying and stretching, or softening process. The again, if you leave the hair on you will need to soak it for about four days or untill the hair begins to slip off. At that point you can remove the hair with a wet rag. The Alum will loosen the roots and the hair just comes right off. I learned that by accident when I was tanning a Hair-on Hide and left it in the Alum Solution too long. Then, you can go ahead and do the drying and softening. Have fun Thanx Jim I truly appreciate the help what type of alum do i get at grocery store and does it need to be neutralized afterwards? thx again Quote
Members rawhide1 Posted April 19, 2009 Members Report Posted April 19, 2009 canemaker There's a site called taxidermy.net they have a ton of information. It's a forum just like this and doesn't cost anything to join. I will warn ya there are some real jerks on that site. But there are a lot good people who will answer your questions also. So just ignore the jerks. They also have a list of stores that carries anything you would ever need to tan a hide. Take a look and maybe it will be of some use. Best of luck!!!!!! Mike Quote
Des804 Posted April 19, 2009 Report Posted April 19, 2009 Well Canemaker, I've tanned a deer hide or two and there is another way besides mushin' up them brains. All you need is a quick trip to the grcery store and buy two cans of Alum. Yep. it's a pickling angent.Now, you can stretch the wet hide in a rack, let dry, and then scrape the hair off while it's still "green" or soak it hair and all. Either works as well as the other. The only difference is that with the hair scraped off first, you only need to soak it in the Alum and water solution for about two days, stiring it a couple of times a day. Then remove the hide, rinse well, and proceed with the drying and stretching, or softening process. The again, if you leave the hair on you will need to soak it for about four days or untill the hair begins to slip off. At that point you can remove the hair with a wet rag. The Alum will loosen the roots and the hair just comes right off. I learned that by accident when I was tanning a Hair-on Hide and left it in the Alum Solution too long. Then, you can go ahead and do the drying and softening. Have fun Do you mix the Alum in water if so how much to two Cans of Alum... Also does this work with other hides as well or just Deerskin ( like Rabbit or other furs ) Quote
Members Jim Posted April 22, 2009 Members Report Posted April 22, 2009 Thanx Jim I truly appreciate the help what type of alum do i get at grocery store and does it need to be neutralized afterwards? thx again Hmm, didn't know they came in different types, I just always got the can that said ALUM. And I don't figure it needs to be neutralized, I never did. I just rinsed the living daylights out of it be for I stretched it for dyying. Quote
Members canemaker Posted May 10, 2009 Author Members Report Posted May 10, 2009 Hmm, didn't know they came in different types, I just always got the can that said ALUM. And I don't figure it needs to be neutralized, I never did. I just rinsed the living daylights out of it be for I stretched it for dyying. Thanks Jim That makes everything so much simpler sorry for the delay in my response i've been considering tanning my computer. its been uncooperative. many thanks to you also mike that site is very informative Quote
Members Jim Posted May 10, 2009 Members Report Posted May 10, 2009 To answer all, yes Alum Tanning works for all hides. Now, it you want the hair left on, soak the hides for two days only. Then rinse and work the hide untill dry. I made a rabbit hide pouch this way that lasted me for about eight years - untill I lost it. Deer hides = two cans Rabbit and other small critters = 1 can Quote
