Hey Everyone,
I'm back again with more questions. ( I promise sooner or later I'll be able to offer advice instead of just questions). I cut some lace with the Tandy lace maker (the black plastic stick). No problem. When it came to dying it, I am pretty sure I ended up with about 20x as much dye on me and the workbench as I did on the lace. I was using a small dauber and dying about 10" at a time on the marble slab. Flip it over and repeat. I managed a fairly even color, not to splotchy. Does anyone have a better method for doing this? Maybe some homemade gizmo to speed things up (it took me a little over 25 minutes to get the color even over 6 yards of lace)?
Thanks everyone
-Aaron
p.s. I'm using the homemade RIT based spirit dye if that makes a difference.
p.s.s. Sorry if this has been asked before. I did a forum search on "dying lace" and came up with 15 pages of results and didn't see anything in the first 10 pages that looked like it would help.
Edited by sandycreek
Remember, I'm no pro....
I very rarely need to dye lace but if it comes up, I add the dye to a container with a snap-on lid and then put the lace in. I swish the dye around the lace and then pull it out to let it dry. It makes things a lot neater and easier. I hope this helps you out a bit.
Never argue with a stupid person. They'll just drag you down to their level and beat you with experience!!
I'm with Frank on this one. A cottage cheese container and a wooden skewer do it for me. The skewer lets me pick up the lace and then I hang it up to dry over a couple layers of newspaper. Oh yeah - rubber exam gloves are another essential.
I tend to use those disposiable gloves (Got tired of walking around with constantly stained fingers) and use old bits of shearling (left overs from saddles) to apply the dye to the lace - upending the bottle onto the shearling then running the lace throught that - applying more dye to the shearling when needed - tends to be the least messy method I have used.
Then with another pair of gloves apply aussie conditioner to the lace - this binds the dye to the lace and stops it coming off.
my very own world within the darkest of corners at ebay
I would go with Troy's method myself - it works for paint and sticks
for me anyway - but yes GLOVES are an important part of the process
Reality is for people who lack imagination
Whether you think you can or think you can't - you are right. ~Henry Ford
I just take the lid off and drop the lace in all but the last two inches or so. After a few seconds of soaking I grab a shop towel wrap it around the lace and pull the lace thought it as I pull it out of the bottle. cut off the two inches that aren't dyed, or give it a quick dip and dry with the towel. hang it out of the way for a bit to dry completely.
Ziploc-type baggie. Put the lace in cover w/dye and carefully "burp" out the air. Mush it around to cover completely then hold a corner of the bag over the bottle and snip it off to empty most all the dye back into the bottle. I remove the lace and rinse, then (still wearing gloves) I rub human hair conditioner into the tangled lace to detangle and hang to dry. Once dry run the lace between a folded piece of sheep wool to "buff" out the un-soaked in conditioner.
[color="#FF8C00"][size="4"][font="Tahoma"][size="5"][i]wag[/i] more,[/size][size="3"] bark less . . . [/size]
happy tails,
tracy[/font][/size][/color]
Thanks for the tips everyone. Sometime the most obvious solution (i.e. dunking lace in the dye) goes flying right past and leaves me in the dust... :dunno:
Thanks
-Aaron
This is also my preferred method - I tend to use a wide mouth glass jar full of stain and coil the lace into that. If you put the lid back on and give the jar a shake it gets rid of any bubbles and ensures a nice even color.
To seal the lace I use Skidmore's Leather Cream on a piece of shearling and simply pull the lace through the shearling to coat both sides and seal the whole job. It is easy to dip the shearling in the Skidmore's pot to 're-charge' it when needed.
Gloves are essential if you don't want to get covered iin dye..
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
  • 2 weeks later...
i do the dyeing BEFORE i make the lace. and if the leather is i little bit flanky, daub the flesh side with resoline or angelus. let dry, make lace, no fuzzys!
