How do ya sharpen an edge beveler.....or do ya just buy a new one??
Thanks,
Dirty Ernie
Edited by dirtyernie
Dirty Ernie
Thanks,
Dirty Ernie
Hi Dirty Ernie!
Your answers can be found on page 95, in Al Stohman's book: "Leathercraft Tools" How to use them, how to sharpen them. This book is very informative on the use and care of all your leatherworking hand tools. I got my copy at Tandy.
Of course, you could just buy a new one, but wouldn't you rather save that money towards the purchas of a new piece of leather? :)
  • Ambassador
If you take a piece of round leather(lacing, a narrow strip, etc) and rub in rouge, then take your edger and PULL it along the strip, it will serve you well.
I have never filed(sharpened) the inside top of mine as none of my jeweler's files are small enough to do it, but I have kept my edgers sharp for years with an occassional strop.
pete
I just run the back of mine over my strop a few time after a days use. It stays nice and sharp.
Thanks so much for the input... I'm very new here and I have just began to make holsters and saddlebags. I'll attempt to sharpen - I hate to buy a new one whenever it gets dull.
Thanks again!
Dirty Ernie
When I was using the slotted style edgers, I sharpened them on the bottom only with either a flat surface or wet-dry wrapped around something the right size. I stropped the inside of the slot with the edge of a piece of stiff cardboard (cereal box to tablet back) with stropping compound rubbed on the edge.
Bruce Johnson
Malachi 4:2
Somebody, I believe it was Badger, said they used a hacksaw frame but instead of a blade they used a tight piece of thick garden string coated in polishing compound to sharpen edge shaves. It works for me.
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
That's funny Ray! I do the same thing. Went and bought some cheap small frames for cutting copper pipe, set each one up with different rouge or different size string. Works like a champ!
Bob
I gotta do that, I've been hitting mine with a super-fine polishing wheel on a Dremel, but it's not getting the inside of the tool...
Dirty Ernie
This is the way Verlane sharpened hers...She would use a 1/2 disk cut from leather and bevel both edges, and attach it to one of the dremel shafts. she would only sharpen the bottom...
I take it one step further and take a fine grit sandpaper and fold it and knock off the burr on the top.
Marlon
