Members Dink Posted May 29, 2009 Members Report Posted May 29, 2009 Ah the down side, It took me quite a while to find the bender but between the bender, two roles of rule, the barrels (containers for storing rule), all the dies and saw, I already had welders is about a $5000 investment. I looked at this when I purchased it as a complete stand alone, additional business to my leather business. Do you have interest in making dies? Dirk, very cool. What does a setup like that cost? Quote
Members Prince Posted May 30, 2009 Author Members Report Posted May 30, 2009 Yes I do, but not as a supplemental business to my leather or metal works, but rather to save in the long haul by making my own as opposed to outsourcing them. I didn't think I'd need a special bender to do them though so it may not really save me so much as I thought. I figured I'd be able to do them with my current tools I've got for making knives and such. I don't really know what clicker dies cost anyway though so it might easily enough not really have saved me so much anyhow. Quote Elaborate Custom Armor, Weapons, And Leather Items at PrinceArmory.com | My DeviantArt Gallery | Facebook |
Members kevinhopkins Posted May 30, 2009 Members Report Posted May 30, 2009 Yes I do, but not as a supplemental business to my leather or metal works, but rather to save in the long haul by making my own as opposed to outsourcing them. I didn't think I'd need a special bender to do them though so it may not really save me so much as I thought. I figured I'd be able to do them with my current tools I've got for making knives and such.I don't really know what clicker dies cost anyway though so it might easily enough not really have saved me so much anyhow. Hi Azmal, For what it's worth, the steel that clicker dies are made from is purchased as just that. You don't have to sharpen it, just cut, bend, weld, and all that stuff. The steel rule dies are a totally different animal. Usually they're either formed around a wood pc, or inset into a piece of wood, like 3/4 plywood or something similar. They have some drawbacks, especially if you're wanting to click a lot of pcs. If they're made in the style that is inset into a pc of wood, you can't see to rapidly position your die, and this will waste a lot of leather in a fairly short time. When we first started manufacturing wallets, we had all of our dies made of steel rule, because of the cost. It turned out that we eventually had them all remade from standard clicker die material, and it was the smartest thing I ever did. The steel rule dies also didn't have the life that a standard clicker die has. it doesn't take much for a steel rule die to get a nick in it, or for it to have a chip come away from the welded seam, and then you're forever having problems cutting clean. If you're not ever cutting any qty of anything, then steel rule might be ok, but I don't think I'd be using it on leather. All boot and shoe factories, (the few remaining) use standard clicker dies. If it will help, I'll gladly give you the phone number of the guy that I think is the cheapest die maker in the country. We just had a wristband die remade the other day, and it cost me 38 bucks, and it had 2 holes in it. If you'll either email me ( kevin@springfieldleather.com ) or call me, ( 800-668-8518) I'll give you his number and address. Sorry to be longwinded! Kevin Quote
Members Dink Posted June 2, 2009 Members Report Posted June 2, 2009 Kevin just trying to clarify what you said about dies. The dies you are refferring to as standard clicker or steel dies, are the ones like we produce out of 3/4 or 11/4" pre sharpened steel rule that is bent and welded with braces but has an open top. And the ones you call steel rule are the ones that are either bedded or wrapped around a wooden form? Dink Quote
Members Tornado220M Posted January 24 Members Report Posted January 24 On 5/26/2009 at 7:41 PM, Dink said: Azmal If you are interested I can get you some pictures of my die making machine, the one I have and am learning to use is a sandvic foot press. The metal used is called steel rule and comes pre sharpened in either 3/4" or 1 1/4" heigth and I believe they are 200' rolls. I am learning and not really profecient with really detailed pieces, but have made a few of my own dyes that I use now. The bracing I use and is used on dyes I have bought is either 3/16" strap in different widths or 1/2" square tubing. With this type of press all the bending is done cold. I use a chop saw for good straight ends, and do the joining welds with a wire feed welder. I do not know of anyone who uses a heat or forging type process to shape dyes, though that does not mean it's not done, but I believe the problem with forging dies is getting the correct temper back in your steel. I have been immediatley cooling dies after welding with water to retemper. There are places you can purchase sharpeners for re-sharpening dyes. As for clickers depending on the size of parts you are clicking, but the thickness you are using could be a struggle with a manually operated clicker. I use an Atom SE 20 and have been very happy with it, super dependable and very little maintenance. My advice is if you are cutting from whole sides, get something with at a large cutting area like a 24 x 48". You should be able to find this size in your price range. The reason I say this is that the newer clickers require both hands to operate and it can be tricky to hold a whole side plus die in place and click with both hands without things sliding. You will also find that many of the clickers out there in this size operate on 240 volt three phase power and will not run on a residential power. this will require that you either use a phase converter or change the motor. I added a rotary phase converter to operate mine. This was around an additional $450 but works very well and was relatively easy to install. That is my two cents worth but I will be happy to try and answer any oyher questions if I can. Dink Hello can anyone tell me where I get the steel for clicker cutters from please ? Quote
