Members Hawk Scarbrough Posted March 5, 2016 Members Report Posted March 5, 2016 I have toyed with buying a strap cutter to cut belts blanks for some time but have always baulked at the cost. I was thinking about making one from scratch but then I had one of those sparks of inspiration… Take one mortise marking tool from the local market tool store I removed the marking pin by knocking through and then used a claw hammer to remove it being careful not to mark the main 'bar' as this is what the leather will eventually ride on. With a very fine blade (junior hacksaw) I cut a slot for the blade from the left hand side as I am right handed – this means that when cutting you will be pushing the blade into the body. I then drilled a pilot hole to take my locking screw (the smallest I had) of which once I had screwed it in once to cut a thread I removed an files the point off to give a flat end to bite into the blade better. The blade is one from my skiver / thong cutting tool but you could use a Stanley blade snapped in half. With the blade in place the screw is tightened to hold it in place And finally a shot of it in use… - you must be wary of the exposed blade but that is the same as a number of models in Stohlmans book So there you have it! - a strap cutter on a budget! Where do you go to by the mortise thing? Quote
Members TZBrown Posted March 6, 2016 Members Report Posted March 6, 2016 (edited) http://www.woodcraft.com/Product/145465/ROSEWOOD-CUTTING-GAUGE.aspx?gclid=CjwKEAiApOq2BRDoo8SVjZHV7TkSJABLe2iDL6YuPIitCc3e5GnnZ4olqAPfSKCCcs1RQast48RGDxoCQf_w_wcB others are available I am sure but that is a place to start Edited March 6, 2016 by TZBrown Quote Life's A Journey It's not to arrive safely at the grave in a well preserved body, But rather to skid in sideways, totally worn out, shouting, Woo Hoo!....What a Ride! My Photos: https://www.flickr.com/photos/56844387@N04/sets/ My Videos: https://www.youtube.com/user/TZBrown01/videos
Members Roq Posted March 7, 2016 Members Report Posted March 7, 2016 sounds like a good tutorial, but without the photos for context..... Like ^^^^^^^^ he said ^^^^^^^^^^^^ pictures just don't show up............ May God bless, Dwight It is a 7 yr old post, shhh don't tell anyone. Quote
