Members bevo Posted March 13, 2008 Members Report Posted March 13, 2008 This is a wallet I made for my nephew depicting the Giant's Logo Quote
steveb Posted March 13, 2008 Report Posted March 13, 2008 (edited) hmmm, looks kinda cool in a fuzzy way, i'd really like to check out your lacing, but youve presented a challenge! Did you look at your pics before you posted them for the world to see and live on in digital perpetuity? Methinks not! 3 quick suggestions when you use a camera: 1 - back up a bit - let your camera focus on the subject 2 - turn off your flash, your drowning your subject in light 3 - shoot at an angle to your subject - head on's tend not to work so good... try it - and see if it works for you, if not, keep noodling around until you find something that looks good - probably take you 15 minutes at most - and i suspect based on the brief look at your leatherwork that you will know when youve got somethng that looks good.... i wanna see how you handled bringing the end of your lacing together ...so try the photo thing again bevo! steveb Edited March 13, 2008 by steveb Quote
electrathon Posted March 13, 2008 Report Posted March 13, 2008 I does look like you have the splice (if I can see it correct in the pic) miswoven. Also, you have the lacing backwards: The outside pattern is on the inside and the side you see when the wallet is closed is the inside pattern. Quote
Members Spider Posted March 13, 2008 Members Report Posted March 13, 2008 Hey cool. I love making stuff for people cause they get all WOW over it. Makes me feel good. Good for you Bevo. Quote
Members bevo Posted March 13, 2008 Author Members Report Posted March 13, 2008 hmmm, looks kinda cool in a fuzzy way, i'd really like to check out your lacing, but youve presented a challenge!Did you look at your pics before you posted them for the world to see and live on in digital perpetuity?Methinks not!3 quick suggestions when you use a camera:1 - back up a bit - let your camera focus on the subject2 - turn off your flash, your drowning your subject in light3 - shoot at an angle to your subject - head on's tend not to work so good...try it - and see if it works for you, if not, keep noodling around until you find something that looks good- probably take you 15 minutes at most - and i suspect based on the brief look at your leatherworkthat you will know when youve got somethng that looks good....i wanna see how you handled bringing the end of your lacing together ...so try the photo thing again bevo!stevebIt looks fuzzy because the picture was reduced. If you double click the picture, it will be full size. Thanks for the tip on taking the pictures. New at this but like learning new things and hearing new ideas. ThanksI does look like you have the splice (if I can see it correct in the pic) miswoven. Also, you have the lacing backwards: The outside pattern is on the inside and the side you see when the wallet is closed is the inside pattern.New at this, just learning, thanks for the tip. Quote
electrathon Posted March 14, 2008 Report Posted March 14, 2008 (edited) New at this, just learning, thanks for the tip. Personally, I still screw up more things than I finish. Keep practicing and learning! Aaron Edited March 14, 2008 by electrathon Quote
