Members jwwright Posted March 13, 2008 Members Report Posted March 13, 2008 We had a great discussion of ideas a little while back about cheyenne roll bindings. I was curious as to everyone's thoughts on straight cantle bindings, or pencil roll, or finger roll........what ever they are called in your part of the world. Specifically 2 things.............do you always use a filler on your straight binds, or just the cantle back, seat and binding cover? If you do generally use a filler, do you put it in seat side, or cantle back side? Thus far, I've done it several ways, and am trying to sort out what method I like best. Also, rawhide on straight bindings........pros and cons? Thanks for your throughts. Quote www.jwwrightsaddlery.com
Members mulefool Posted March 13, 2008 Members Report Posted March 13, 2008 What is the difference between a pencil roll and a finger roll? I haven't heard either of these terms. As far as the filler I put it on the front. It's just how I learned. But if there might be a good reason to do it on the back of the cantle I could be talked out of it. Quote www.horseandmulegear.com
Bob Posted March 14, 2008 Report Posted March 14, 2008 We had a great discussion of ideas a little while back about cheyenne roll bindings. I was curious as to everyone's thoughts on straight cantle bindings, or pencil roll, or finger roll........what ever they are called in your part of the world. Specifically 2 things.............do you always use a filler on your straight binds, or just the cantle back, seat and binding cover? If you do generally use a filler, do you put it in seat side, or cantle back side? Thus far, I've done it several ways, and am trying to sort out what method I like best. Also, rawhide on straight bindings........pros and cons? Thanks for your throughts. JW, it's called a pencil roll around these parts.... I always use a plug on this binding. for several reasons. Firstly, when the cantle back goes on, it's higher than needs to be, then after cutting a strap 5/8 or 3/4 with a draw knife, it's straight. Then I glue it on top of the edge of the cantle and trim the cantle back off flush with the plug i just glued down, thats how i get it straight with the wood. Then once the seat is glued down, it's trimmed off to match the cantle back. Therefore the plug or filler is between the two. The second main reason is the binding looks more substanial or beefy, stronger. On the pencil bindings a person can use a heavy binding too. If you don't mind working at it. you can put in 7 - 9 oz binding. Thats what I aim for. Further more, if you wanted to scallop the back edge, the heavy binding is less likely to curl up on the scallops, also if your into hiding the stitches, you will require a heavier binding anyway. Quote Bob Goudreault www.kamloopssaddlery.com
Moderator bruce johnson Posted March 14, 2008 Moderator Report Posted March 14, 2008 JW, I haven't done a ton of these either. I was taught to put my fillers on the back, probably doesn't matter a whole lot once you have the reasons set in your mind? The last Cheyenne roll I did, I put it on the front and got a pretty good break. That was prior to the Cheyenne roll discussion, and I have some new fish to fry on the next couple after ythat discussion. Rawhide bindings are one of those things guys like or hate. Some guys can keep them intact. Others will wear and abrade laying under the gooseneck on the flatbed. Then the weather will eat them. I was shown a few years ago to put a strip of heavy skirting on from the back the width of the crimp depth. Glue it in place, secure it with a running stitch, and put the binding over that. The backside stitching lays right in the channel under that little lip. It gives you a little ridge to catch the fingers into if you are a saddle lifter and not a slinger. Makes kind of a cute little lip and look. I am not sure if it is a finger roll, pencil roll, or what. I am thinking those terms could stand some explainin'. I would also like to expand on this and have some guys explain how they do a blind stitch. I had one of Ryan Cope's over here, and it was about as good a job as it gets. Very clean and no marks evident. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members jwwright Posted March 14, 2008 Author Members Report Posted March 14, 2008 Mule.........I really don't know that there is a difference in finger roll or pencil roll or straight binding. From here, south to Texas it is most often referred to as a finger roll. Me, I've always called it a straight bind. Bob and Bruce........great ideas, as always, Many Thanks. I am working on a wade with a straight bind currently, and this gives me more to chew cud on. JW Quote www.jwwrightsaddlery.com
Members kseidel Posted March 14, 2008 Members Report Posted March 14, 2008 Around here, pencil rolls and finger rolls refer to the shape on the edge of your hat brim! Straight up cantle bindings have a tendency to "curl" forward into the riders seat. It is important to keep the bound edge straight up all around the edge of the cantle. If you do not use a plug and secure it to the cantle, the thicker and firmer leather of the seat will pull the binding forward over time. I use a firm strip of about 8 oz. leather glued and nailed to the back of the cantle. I leave about 3/4 to 1 inch below the edge of the cantle and skive to a smooth transition an the cantle back. Then shape it tight to the top edge keeping the front edge in the center of the cantle edge. (lots of edges in that sentence) Then put the cantle back on. I find it easier to trim to desired width after the cantle back is in place. When the seat is glued into place, break the seat over the top of the cantle and crimp it tightly to the back and filler this should leave a depression where your seat folds back over the tree before extending straight up around the shape of the cantle. This depression will allow your binding thickness to fit without protruding into the plane of the seat. The plane of the seat should then follow out to the edge of the cantle binding. I like to use about 10 oz leather for my cantle bindings. I do not care for rawhide on straight bindings because the rawhide continues to shrink and over time will pull the edge into the seat. I have also found that rawhide wears out faster than leather. Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
Members greg gomersall Posted March 14, 2008 Members Report Posted March 14, 2008 I was taught that when talking about saddles there were 2 places for rawhide. The first was on the tree the second was on the cow. I agree with Keith that it will wear out faster than leather and also due to the fact it NEVER quits shrinking it will pull and eventually cut the stitches. If you look back on history few if any of the legendary makers used rawhide bindings. In the last 25 years society has decided that due to the phrase "Rawhide Tough" we have assumed that means on everything. On some items given the proper care it is great stuff but on any exposed saddle parts it is a mistake. I will do it if a customer insists but I due my dangest to dissuade them. Greg Quote
Members wyoming Posted March 14, 2008 Members Report Posted March 14, 2008 I have to agree that rawhide doesn't belong on a cantle. I tell customers that you never see an old saddle with a rawhide binding, they don't last. I am replacing one right now that someone insisted on, that is probably only about fifteen years old. The rawhide had shrunk and all the stitches were ripped out. John Quote
Members jwwright Posted March 14, 2008 Author Members Report Posted March 14, 2008 Thanks for your thoughts Keith, Greg and Wyoming. Keith, mostly around this part of the world, most hats are in some form of taco shape, maybe tater chip........not many amish looking ufo lids to be seen. That's a friendly joke, hope all have a sense of humor. Really good ideas on the fillers for straight binds, and the opinions on rawhide binding confirm what my thoughts have always been. Thanks again fellers. JW Quote www.jwwrightsaddlery.com
Members kseidel Posted March 14, 2008 Members Report Posted March 14, 2008 JW, A pencil roll on a taco brim.... Hmm. That would be a way to make it even more "unique." Ha Ha. You must be from around West Texas.? Keith Quote Keith Seidel Seidel's Saddlery www.seidelsaddlery.com
