I know the information, I'm looking for, is here, someplace but after an hour of searching I still cannot find it.
I have a Tandy manual embosser. My question is at what point do you run the belt through the machine & what should I do or not do before embossing. The belt is dyed, glued, sewn & edged. No sealer coat has been applied.
This embossing was an after thought so I may have gone too far already with the belt to emboss.
While I've never done it, it makes sense to me that it be done the same as stamping, carving, etc.....wet or case the leather, then when it is at that right time of drying, run it through the embosser....first, before dying, sewing, finishing, etc....
You haven't sealed so it will still work how ever I must say if you want the color to be as is then your going to be unhappy if you have used a water base dye othe wise you should be fine get it wet let it case run it threw and let dry good luck
Josh
If it is the old style that tandy used to sell chances are the emboss will not be as crisp as when done prior to dyeing and the crosshatch of the lower wheel will imprint the back of the belt but other than keeping the belt straight as it goes thru the rollers it should work fine. If it is the new style machine I havn't a clue cause I don't have one of those.
I'm with Jordan on this. I have an old Tandy machine and a Tippmann embosser. The Tandy works fine on new cased leather but it may be hard to adjust the pressure on the roller accurately. In this instance, with a part finished belt, the dye may also tend to harden the surface of the leather making it more resistant to an impression.
The Tippman is a different story and has all the pressure adjustment you need to deal with a job like this. IMHO it is a vastly superior machine.
Ray
