Singer
W251394
112W115
those are the two numbers on it, it's a Singer machine and in good shape what is it worth what can it do please help thanks
Josh
Art I would enjoy some input from you.
Josh
Dusty Chaps Leather
Seven O Saddle Shop
801-809-8456
Keep moving forward! On a horse.
Hebrews 4:12
My link
I think the second number is your model number. In this case, 112w115.
http://parts.singerco.com/IPinstManuals/11...3_W116_W120.pdf
Mike DeLoach
Hey Josh, the machine is a 2 needle compound feed machine. It was, for a long time, the best that there was. They can still be rebuilt and last a lifetime. Hope this helps. Steve
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
That's great stuff but can it sew leather and what kind.
Josh
Josh
Dusty Chaps Leather
Seven O Saddle Shop
801-809-8456
Hebrews 4:12
My link
It should handle 8-10 oz thickness of leather.
They are used alot for belts,dog collars & etc.
Guage parts are cheap too if you want to change the distance between needles.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Can you use it with just one needle?
And is this just a crazy fast machine or can the speed be controlled.
Thanks Josh
Josh
Dusty Chaps Leather
Seven O Saddle Shop
801-809-8456
Hebrews 4:12
My link
Sewing speed is a direct result of the motor on the machine. You should be able to fit it with one of the DC servo motors and a reducer. If you don't want to go that far yet, you can somewhat reduce the speed by putting a smaller pulley on the motor shaft, and a larger one on the head. It works just like gear ratios in a transmission.
Mike DeLoach
So the last question is, can I use just one neddle on this unit.
And is a working one of these worth $290
thanks
Josh
Josh
Dusty Chaps Leather
Seven O Saddle Shop
801-809-8456
Hebrews 4:12
My link
yes,you can use a single needle if needed but the foot will be wide unless you buy one & grind it,is it sews ok it should be worth $290.00
If you want to slow it down.We now have a DC servo motor w/a built in reducer that mounts on the standard 3-holes as any other motor for less tha buying the two seperate & it's alot easier to install.
Bob Kovar
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
