bkingery Report post Posted January 28, 2011 I've been trying to find a deadblow mallet that doesnt feel like it would poke a whole through it if I hit it hard and can't seem to find one. Any ideas???? Quote Share this post Link to post Share on other sites
almac Report post Posted January 29, 2011 how about something like a 1 ton press like this? http://www.princessauto.com/workshop/garage/fabrication-and-equipment/shop-press/3460011-1-ton-arbor-press not too expensive, and im sure you can find something like it locally... Quote Share this post Link to post Share on other sites
bkingery Report post Posted January 29, 2011 how about something like a 1 ton press like this? http://www.princessa...ton-arbor-press not too expensive, and im sure you can find something like it locally... I actually have thought about one of the presses but they all have such narrow throats so I think I will probably just use my shopsmith. B Quote Share this post Link to post Share on other sites
Ellen Report post Posted February 7, 2011 Tandy's ram foot and tabletop drill press here. Quote Share this post Link to post Share on other sites
leatherworklee Report post Posted March 19, 2012 I have an old drill press minus the motor that I bought for $15.00 that works quite well. The most important things to consider are: Is your leather properly cased? Review casing procedures elsewhere on this site. And do you have a good solid surface under your leather? A good marble or granite block makes a big difference. Placing the tooling block on a really solid bench helps to eliminate a lot of bounce. I often use a "Hefty Handle" as well. I was having problems with bounce after moving my shop and found that making an extra leg for the table that I was using for a tooling bench really helped. I used a piece of 4X4 located directly under my marble block.I Hope this ramble helps. Quote Share this post Link to post Share on other sites
Davy Report post Posted September 29, 2012 For embossing tools marble is the best base to deaden the blow . I use 2" marble and never had a tool bounce yet . A good heavy rawhide mallet for tooling is the go and a lighter one for beveling works well for me . Also the leather needs to be just wet enough to help the tool leave a nice crisp print . If its too wet it wil be spongey and the edge of the print won't be sharp and clear , it will also displace too much leather causing distortion which is no good at all . If you get the wetness right you can emboss large areas without having to rubber cement your job to X-ray film or whatever else . Hit hard for stamps with a large surface area and lightly tap for those small triangle or mules foot stamps . On 3.5mm leather I hit hard but on 1mm to 1.5mm I go very carefully . If you wet your leather a bit too much wait till it dries out a bit , the more you do the easier it gets . Finally try using your stamps at different angles , not all stamps lend themselves to this but by experimenting you can get a whole new pattern base . 1 stamp can give you a few different impressions that are really noticeable after antique is applied . Good luck , there's nothing more satisfying than creating a pattern that looks great , is one of a kind and that you know nobody will ever duplicate it !!! Cheers , Dave . Quote Share this post Link to post Share on other sites
EmbossingDieCompany Report post Posted October 2, 2012 You might also want to consider a table top vice......I bought this one from Harbor Freight for $20. My preference is to use a vice/press rather than a mallet......I believe you get a better/crisper/deeper/more accurate impression with a press verses the mallet. Quote Share this post Link to post Share on other sites
IrishD Report post Posted October 12, 2012 Very informative thread! After pounding my arm into oblivion a few months ago, I went out to my husband's work shed and looked around...and there I saw his drill press! By opening the jaws all the way, I found it was a perfect fit for the 3-D Stamps I have. The stampings came out clearer than hammering them in, but my impressions still weren't coming out as crisp as I wanted. Now, I know why! I had been using a 1" thick piece of wood under the leather! Now I know I should have been using either metal or marble! DUH! Thanks for all the great info! Quote Share this post Link to post Share on other sites
camano ridge Report post Posted October 12, 2012 I would reccomend the marble or similar material. If you get damp leather in contact with metal (steal iron etc.) you may end up with some black caused by iron oxide that you don't want. Quote Share this post Link to post Share on other sites
lwm803 Report post Posted October 13, 2012 (edited) I did these today as a test of my newly modified arbor press. I used Tandy 3D stamps directly under the ram of the press (no handle on the stamp). The press has a 1/4" thick aluminum plate but I had a 1" thick aluminum bar on top of that under the leather. I reckon these came out pretty sharp, though I could have used a little less pressure on the smaller pterodactyl (my favorite stamp).. Edited October 13, 2012 by lwm803 Quote Share this post Link to post Share on other sites
St8LineGunsmith Report post Posted October 19, 2012 harbor freight has 1 ton arbor presses for $50.00 for a one shot stamp here is how I use 3D stamps case the leather and let the water soak in and the surface dry then use a ram foot on the stamp handle and hit the stamp one good blow to set the impression then make sure the stamp is firmly seated into the impression and hit the stamp four more times by applying slight pressure to each side of the stamp. check to make sure the stamp is properly seated into the impression before every strike to keep from getting a double impression it is essential to have a marble or granite slab to get a good deep tool impression. I always get good results with this method. Quote Share this post Link to post Share on other sites
EmbossingDieCompany Report post Posted November 17, 2012 I've found that using a piece of 1/2" thick acrylic works really well as a backer. I simply take the 1/2" acrylic, lay the leather on top, carefully place the embossing die exactly where I want it, then put that "sandwich" (acrylic-leather-die) into a tabletop vice, tighten, loosen, done. It takes about 10 seconds each and I get a clear, crisp, deep and perfectly placed impression every time. And it works great for doing bracelets that I bought from Tandy.......I cut a 1/2" thick piece of acrylic that is about 8" x 2" for doing these bracelets. I'm attaching a picture of bracelets that I did, but I don't have an actual picture of the acrylic backer. If you want to find a cheap piece of 1/2" thick acrylic, you can go to almost any craft store (Michaels, Hobby Lobby, etc.) and look in the picture frame section.......they usually have picture frames that are actually two pieces of 1/2" thick acrylic that are held together with a magnet (you're supposed to sandwich the picture between the two).....and they usually come in 5"x7" and 8" x 10" sizes. Quote Share this post Link to post Share on other sites
carr52 Report post Posted August 23, 2015 I've been trying to find a deadblow mallet that doesnt feel like it would poke a whole through it if I hit it hard and can't seem to find one. Any ideas???? http://www.harborfreight.com/catalogsearch/result?q=dead+blow+hammer Quote Share this post Link to post Share on other sites
Stan Report post Posted October 5, 2015 Howdy! I just finished a new (for me) work bench. I saw one on You-Tube and copied it. It is a piece of fir log about 12" in diameter and 27" long. I took off the bark and then sanded the entire log. I used some stain and then varnish. It sets in front of me when I am on a chair. It is heavy and solid, but easily moved around. I can use a 1/2" piece of steel on top to set rivets, a piece of marble to set 3D stamps, a piece of thick rubber to use a punch, etc. The main advantage is, it is inexpensive to make. Did I say,"It is very solid!"? A good piece of hardwood would be better than fir, but where I live there are only pine and fir. You just gotta love this site and all the great people here. Stan Quote Share this post Link to post Share on other sites
