Doug,
Come and visit me and I'll see if I can help ...
Aargh! I'm having a wretched time using this new dye. It has a very weak coverage, and if I use a wool applicator, it foams up and leaves speckles. The strokes don't seem to blend as well as alcohol base dyes, but I made it work by giving about 3 extra rubdowns with dye on a cloth rag, but that's too many passes. I'm at the point of considering this stuff unuseable. I'd rate the difficulty of using it at a 7 on a ten scale. Any advice?
Doug
JOhan
****Afrikaans: Leerwerker *****  ****Zulu: lesikhumba isisebenzi  Latvian: ādas darba ņēmējs *****Russian: кожа работника ****English: Leatherworker ****Dutch: Lederbewerker ****Flemish: Leerbewerker ****Hebrew: עור פועל ****German: Leder Handwerker ****Hungarian: Bőrdíszműves ****Turkish: deri işçisi ****French: Artisan du Cuir ****Spanish: Artesano de Cuero ****Norwegian: Skinn kunstners ****Swedish: Läderhantverkare ****Greek: δερμάτινα εργαζόμενος  Sotho: mosebeletsi oa letlalo
  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
hi guys just thought i would throw my 2cents worth in. its not the die but the method of use that needs practice the dies in of any ones make be it solvent based or water based need working with and they use different methods of application. i have seen great results with both dies, not in my work but in others who have put in the work with them. i use the spirit based because that's what i learned on. but that does not mean i cant get the same results with the water ones just need to practice with them.
Here is an interesting timeline:
First Picture - June 2004 - I colored the florals on the purse with Fiebings spirit based dyes.
Next three pictures - May 2007 - three years later - most red and green color faded, brown gusset still OK - I redo one half of the purse with Eco Flo water based dyes.
Tomorrow I will add the picture I took today so that you can see what the purse looks like today after more than two years again ....
JOhan
Here is the same purse yesterday: more than two years after I redid half the flowers in Eco Flow dyes:
JOhan
Looks good....what did you seal/finish it with?....and has it been used on a daily basis?
Rayban
www.rgleather.net
It hangs in my store and people handle it every day - I just treat it every six months or so with Dr Jackson's Hide Rejuvenator.
JOhan
As an artist that works with leather, I really enjoy working with the Eco-Flo dyes. Comparing the water-based Eco-Flo dyes to alcohol base dyes is an unfair comparison. It would be like a painter comparing watercolors to oil paint. They both work great, but in different ways. For large areas I use an aerosol sprayer, and get a good even coverage.
As a parent that has children that attend many of the youth classes that Tandy puts on for different groups, I like the water-based dyes easy clean up and no solvents needed.
Considering the wide customer base and new government regulations for the craft industry, I think Tandy is doing a great job. Nobody is ever going to be everything to everyone.
Thanks, Johan, for the offer of help. I'll be up in Mpls soon, and I'll stop in. Also, Kate, thanks for the info about colorfastness, and Johan , for your pictures. Good news, since my helmets are worn outdoors in the sun.
But, I'm worried now about rainshowers, as I just sent a customer a really nice helm dyed with EF. I did treat it with Aussie Balm, and then with Resolene Acrylic, so I'm fairly confident it'll be ok.
Also, I didn't know about casing before dyeing. That's bound to help. So, I'm encouraged about using the EF...just a matter of learning new techniques.
But, I'm seeking people's opinions on whether to use water base or spirit base for the helms. I like the colorfastness, but I'm not sure now about the waterfastness, and if sealing the leather would be reliable. I'd like to pick one and stick with it, so my results will be similar, and down the line, I won't be confused as to which dye I used on which helmet.
Here's a pic of the EF helm.
I'm amazed at how far this thread has gone.
Doug
One thing I am a very firm believer in, is testing. I would pick a prime piece of leather, dye it as described, Doug, seal it, and then take it outside and hose it down, like a good rain shower. Do not overdo it, but see how the sealant holds up.
I have heard of mug makers sealing with SuperSheen and other mug makers sealing with molten beeswax - these could also be options for helms. And then there is Tankote, that seems to seal against newly made belts bleeding off on clothes.
JOhan
