Members Big Papa Leather Posted September 28, 2009 Members Report Posted September 28, 2009 After doing some research, I found out that there are many processes already out there for transferring a digital image to leather. The sublimation process is possible and being done currently with a few different twists in outcomes. As Rubo said there are some who apply a film to the leather, which is like a decal over the top. One of the most promising one I saw for a home crafter or small business was a process in which using common readily available sublimation inks, a t-shirt heat press and an after treatment to seal the ink (which provides a little protection from scratching and scuffing the art.) According to the write-up, the penetration of the ink is dependant on the leather. A sealed, gloss leather is tougher to protect the image than say a porrus leather. I have a request into a guy that does this type of work and maybe I can see if I can get him to print up a few things to see if it works. Allen PS As far as patenting the process, unless Rubo has come up with a radically different way to do this process, I would seriously think about making sure I am not duplicating someone elses work. I found several different patents and processes that are (although still in thier "infantcy") already doing this very thing. I'd hate to see someone spend tons of money to try and patent a process that is already estabilished. Quote Big Papa Leather
Members DCKNIVES Posted September 28, 2009 Members Report Posted September 28, 2009 I would agree, patents are very expensive and usually fruitless these days.Even if you were lucky enough to get one, defending it is your responsibilty.Anyways I have been using the film technique and coat mine with Feibings Leather Sheen.I have done alot of testing, first made several test pieces to try and destroy, and make some sheaths to give out.I gave some to my regular customers to use and give me feedback.The film holds up extremely well and aside from what the OP said,I believe it has a very leathery feel to it.I have even been able to bevel a background on it and mold it.Dave Quote http://dcknivesandle...lademakers.com/
Members Rubo Posted September 28, 2009 Author Members Report Posted September 28, 2009 Hello folks, thanks for all the interest. Really appreciated - I learn a lot, believe me. As far as sublimation - I'm over it, so I will let it go - sublimation doesn't work - at least for my purposes - the reason being the pressure of the press - leather is a sponge, in a sense, so once you apply the heat and the pressure to transfer the image, after a while it starts expanding - so you loose the sharpness of the image. Then there is an issue with the coating (for sublimation) - that one severely restricts your leather options. I've done it and abandoned it. The prints fade. The other option is printing with UV inks on a flatbed printer - BIG bucks. The image looks like an inkjet print (dots etc, because of non-uniform surface of the leather). The coating I use happen to penetrate the leather and some of it stays on top - we have some mechanical tests done on it (some 50 000 revolutions, something or another - essentially, the life time of the item) - works like a charm. Same with UV fastness. I got the coating from a guy who has no idea about leather - he makes the staff for absolutely different purposes. I've got some more pics to show - same process for all the things you see. No, it's not a wrap. No, it's not a water transfer. It's not an airbrush. P.S. For Allen - I'd love to see the results of your search on leather printing in, as you said,"infancy". I'll print some images for you to play with in return;) Cheers. Rubo Quote
Members brian mrbac chapman Posted September 28, 2009 Members Report Posted September 28, 2009 almost looks airbrushed or tattooed on there. Quote MrBac
Members Big Papa Leather Posted September 28, 2009 Members Report Posted September 28, 2009 Hey Bro Rubo, No disrespect intended. The items and articles including patent searches are new... in the last 3 years so yes, so the processes I am referring to in the leather world (thousands of years) still an infant. The information is readily available on the internet with a few search terms. I am glad you have a process that works for you. Good luck with it. Be advised if you come to a place like Leatherworker.net and post a process like you did, you will have curious people ask questions. Proprietary or not, as a whole, LW is a sharing community. So don't get your gander up cause someone is curious about the process. We're all friends here... you included. We all try to advance leather working as a trade and as a hobby. I will still have my buddy do the sublimation printing as I said I would if for no other reason to bang my own head up against the wall. Just curiosity mainly. Allen Quote Big Papa Leather
Members TomBanwell Posted September 28, 2009 Members Report Posted September 28, 2009 Will it work on veg tan leather, which is then cased and shaped? I'm a mask maker. Thanks, Quote
Members Rubo Posted September 29, 2009 Author Members Report Posted September 29, 2009 Will it work on veg tan leather, which is then cased and shaped? I'm a mask maker. Thanks, If you want me to try, send some skin. Contact me off the list and I'll give you the address. Quote
Members Rayban Posted October 5, 2009 Members Report Posted October 5, 2009 (edited) One of the companies I do work for claim that they can print on anything that will lay flat. They have several different large format, flat bed digital printers...I've seen them print on stone, glass, foam core, plexi, vinyl, etc.......I'll ask what they think of leather...... Personally, too gimmicky for me. Edited October 5, 2009 by Rayban Quote Raybanwww.rgleather.net
Members Amy Posted October 7, 2009 Members Report Posted October 7, 2009 Hello folks, Brand new business. Name is LeatherFX. Based in Los Angeles. My first post here - want to show what we do here - just one picture for now - too busy to even to get the web site up - anyway, we do full color printing on leather - any leather, pretty much - coated, uncoated, crust, even snake skin. My customers make garments, shoes, handbags, belts, pillows, furniture, seat covers - anything you can think that is leather. The way it works - the customer provides the artwork and the skin, we do the job and everybody's happy. Or we can do the whole thing locally and ship the goods. If anybody wants to know more please contact via e-mail. I won't discuss the printing process though - it's proprietary- sorry, folks. Enjoy! Believe we have something in common. http://www.imcglobalinc.com Quote
Moderator Johanna Posted October 7, 2009 Moderator Report Posted October 7, 2009 Amy and Rubo- I am intrigued. I've been thinking about the potential for this technology since I met Billy 2shews. I never thought much about the market for customer give-aways, dismissing it thinking "plastic is cheaper". But people tend to keep things they perceive as valuable, or find useful and durable, and right there leather fills a niche like no other, and the market certainly expands beyond leatherworkers. If either of you want to donate 10,000 key fobs with the leatherworker banner on them and your "donated by" name and number. to be given to all members who want one, we would be delighted. Maybe some leather folks who run companies would like to have some spiffy things to pass out to school children on tours, business partners and friends, place in trade show baskets, or even bigger projects- new briefcases for everybody! How cool is it to run a leather company and have unique exciting freebies and gifts, custom designed, at affordable prices? Hey best of luck to both of you- I hope you guys all make a go of it. I'd like to see more leather than plastic junk, of course. Looking at what you do opens a whole new dimension using leather. Johanna Quote You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
