Howdy;
I have a National brand model 306N (Made in Japan) walking foot machine used to sew vinyl and leather. It came with one M size black bobbin case. I usually pre-wind a bunch of bobbins with whatever thread I am going to use on a job and would like to obtain some extra proper bobbin cases for this machine. The bobbins are large M style (1" x 3/8"). The machine has some parts stamped Seiko and is made in Japan. It looks sort of like a Consew 206 series machine. I bought some M bobbin cases on eBay, supposedly compatible with my machine, but they had to be ground down at the upper-left opening, to allow the cases to fit into the shuttle. Also, the thread comes out of the springs in a jerky flow and causes the stitch knots to move up and down.
Apparently, this machine uses a non-standard bobbin case, with a much wider opening on top. This is because the case has to clear two tiny screws on top of the shuttle assembly, about 1/4" apart. The cases I bought do not clear the left screw head and cause the case to jam, unless it's left tab is ground off at the opening on top (which I did, with limited success).
I have posted a group of pictures below to show what the OEM bobbin case and the machine looks like.
Hopefully, somebody here has a similar machine and/or knows where I can get the proper bobbin cases for this machine. If you have some you don't need I'll be happy to buy them from you.
Thanks in advance, Wiz
M-Bobbin-Case-1.jpg M-Bobbin-Case-2.jpg M-Bobbin-Case-3.jpg M-Bobbin-Case-4.jpg M-Bobbin-Case-5.jpg
National-306N-Hook-#1.jpg National-306N-Hook-and-Case.jpg National-306N-#1.jpg National-306N-#2.jpg National-306N-needle-feet-p.jpg
Edited by Wizcrafts
Posted IMHO, by Wiz
Hello,I used the sell the Nationals & have the correct case for you.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Hello, the bobbin case is a Consew 206 RB bobbin case and Bob Kovar has it. Thanks, Steve
Thank You
Steve Tayrien
Leather Machine Co., Inc.
2141 E. Philadelphia St. Unit "U"
Ontario, California 91761
1-866-962-9880
http://www.leathermachineco.com
cobra@leathermachineco.com
Thank you all for your replies. I now have a new bobbin case from Bob Kovar in Toledo! It works perfectly!
I also got a pound of #138 nylon thread from him at a very good price.
Posted IMHO, by Wiz
