I've been using a flex shaft rotary tool for several months now and don't know why I had waited so long to get one.
I figure I should be taking out the flex shaft and oiling it at least twice a year. Is there a good general lubricant I can use or should I get the lubricant that Foredom sells?
Thanks,
Ed
  • Ambassador
Ed i use the Lithium (sp) WHITE GREASE ON MINE.
Luke
Thanks, Luke.
I was close to using the grease I use for my speed reducer, but I had read warnings not to do so, something about heat build up.
Do you think it matters whether I get the spray on or rub on lithium white grease, as some places have only the spray on? My thinking is that a tub of the rub on grease would be best.
Ed
if heat build up is an issue, maybe try graphite powder instead of grease?
"I gotta have more cowbell!" Cristopher Walken - SNL
  • 2 weeks later...
but the kitchen cabinets no longer squeak.
LOL
