ETW Grumpy Posted March 31, 2008 Report Posted March 31, 2008 I can get rivet type Sam Browne snaps at Tandy, do I need a specific setter/anvil to set them? Does anyone make a screw on Sam Browne snap? Quote
Ambassador Luke Hatley Posted March 31, 2008 Ambassador Report Posted March 31, 2008 Hey Grumpy, i see you are still Hanging.......Hang in there... YES YOU WILL NEED THE SETTER FOR THE SAM BROWN POST and tandy also has the screw attached POST. hope this helps.... Quote
ETW Grumpy Posted March 31, 2008 Author Report Posted March 31, 2008 Thanks Luke. I'll hunt' em up at the local Tandy. Yeah I'm still hanging in. To ornery to quit. Sending you a PM. Quote
Members kagekeeper Posted April 9, 2008 Members Report Posted April 9, 2008 GRUMPY, Tandy does indeed have the SAM brown posts. i try to use them as much as possible, less concern coming off in my opinion. gives it a great look as well. i didn't have a setter for it and just used a heavy rawhide mallet to drive it home and worked great i thought, the screw backs seem to come loose a bit easier unless ya use lock tight or some clear nail polish that will still allow you to remove it ONLY when YOU want to. Quote
ETW Grumpy Posted April 9, 2008 Author Report Posted April 9, 2008 Thanks kagekeeper. I was thinking about using the screw on type with some Loctite because it's going on something that will not see a lot of stress. Quote
Members kagekeeper Posted April 9, 2008 Members Report Posted April 9, 2008 I'm glad i could help Grumpy... .I'm still a newbie to all this, so what little i can offer to anyone is always a pleasure. just remember if u have never used the SAM brown b4, be sure to cut the small slit next to the hole Quote
