Members RunningRoan Posted December 10, 2009 Members Report Posted December 10, 2009 I have decided to make myself a fancy leather strap for my laptop case. It'll be tooling leather on top and lined on the bottom. I would like to flare out the strap and pad it underneath where it will rest my shoulder. Wondering what material I should use for the padding and where to find it? I was thinking foam of some kind? I suppose I could live without the padding, but It would be more comfortable! Quote
dirtclod Posted December 10, 2009 Report Posted December 10, 2009 I have used 1/4 neoprene a few times and it works fine. On the bottom i would use a piecs of suede to keep it from slipping. You can get the neoprene on ebay. Look for neoprene sheets. I belive that whats i found it listed under. Quote I'm old enough to know that i don't know everything.
Members RunningRoan Posted December 11, 2009 Author Members Report Posted December 11, 2009 I have used 1/4 neoprene a few times and it works fine. On the bottom i would use a piecs of suede to keep it from slipping. You can get the neoprene on ebay. Look for neoprene sheets. I belive that whats i found it listed under. I didn't even think of neoprene! That probably won't pack down like foam would. Thanks for the suggestion! Quote
Elliot Posted December 11, 2009 Report Posted December 11, 2009 I didn't even think of neoprene! That probably won't pack down like foam would. Thanks for the suggestion! A patch for wet suit works well for this. Buy enough for 2 and you will not have to go back a 2nd time. Buy for only one and it seams something will go wrong. Any how that how it works for me. Quote
Members dustin29 Posted December 11, 2009 Members Report Posted December 11, 2009 Where do you buy neoprene? Thank You. Quote
Members Somawas Posted December 11, 2009 Members Report Posted December 11, 2009 This stuff from Tandy: http://www.tandyleatherfactory.com/search/searchresults/9064-01.aspx?feature=Product_7&kw=padding Quote
