Ambassador pete Posted February 5, 2010 Ambassador Report Posted February 5, 2010 Chocolate is my favorite color- so I fill a little nestles chocolate bottle like the kind that you out into a school lunchbox, with Bick's #4 almost to the top, and pour in(for me) about 3 tsp of dye. If you have one of those Nyquil or cough medicine cups it's about 3/4 full. Experiment and find a shade that you like. Kevin Hopkins ttold me about it and said that he was experimenting as to how much to use. I got the impression that bick's wouldn't mix with it if you used too much but I haven't found that to be the case. I rarely use antique anymore. I out on a coat or two of Bee Natural RTC as a resist and then the Bick's. You don't have to rub it off afterwards, use as much as you like (a little goes a long way) and it leaves the piece smooth and protected like a coat of shoe polish. Plus the Bick's really gets into the tooling because it's so liquid-y. Quote
Members Bronson Posted February 6, 2010 Members Report Posted February 6, 2010 A custom holster maker told me about a trick I am going to try. We were talking about the challenge of getting an even coat with brown. He said put a very thin, light coat of Neatsfoot oil on it just before you dye and it will help pull the dye in more evenly. I've not tried this out yet but hope to this weekend. If you try it and get some results, good or bad, let me know. I tried it on some scrap and it looked good. I didn't get any pics and I've long since thrown it away. I've also read of dying while the leather is still slightly damp with water. Bronson Quote
Members JeffGC Posted February 19, 2010 Members Report Posted February 19, 2010 (edited) A few days ago, I dip dyed a holster (J-Frame) in Fiebing's Medium Brown, thinned 50% with denatured alcohol. The leather was Wickett & Craig and it had been plated. The holster was sewn and formed. The leather was cleaned with oxalic acid, wiped with a damp sponge and then cleaned with Fiebing's #12 Deglazer. Then it was submerged for 30 seconds in the dye and hung on a rod to dry. The results were interesting. Any area that had received any pressure was lighter. This included areas of hard forming to the weapon and even on the reverse side of the leather, in the area of the needle plate (Tippmann Boss sewing machine). Areas that did not receive pressure during the manufacturing process accepted the dye evenly. This really got me to thinking, asking myself the question of how the big holster makers produce holsters with such even dye application. This morning, I spoke with the technical people at Wickett & Craig and Fiebing's. I also spoke with a very knowledgeable contact at Tippmann. I learned a few interesting things. Many of the big holster makers purchase vat dyed leather from Wicket & Craig. The dye goes completely through the leather, not even requiring dye on the edges. Everyone agreed that spraying the dye before doing anything to the leather would result in a more even absorption of the dye. Last week, I did spray dye onto a holster (LCP) using a Paasche AUTF trim gun. The leather had been basket stamped but, otherwise, no compression from forming. The dye laydown was smooth and even. I reached a couple of conclusions: Dip dying will work on very dark colors; i.e., dark brown and black. If you want even, light colors, spray it. A few other points worth comments: I did experiment with the Bick 4/dye mixture on a knife sheath. It worked very well but did not harden the leather, which I want. After dying, I finish with Fiebing's Bag Kote and then Renaissance Wax. Jeff Edited February 19, 2010 by JeffGC Quote
Members JeffGC Posted February 21, 2010 Members Report Posted February 21, 2010 Yesterday, I removed the top finish (Bag Kote) with Deglazer so that I could redye the holster. I dip dyed in the same solution (see previous post) but extended the time to about two minutes. When the holster dried, I noticed the paths of the machine presser foot accepted dye differently, being slightly darker. I applied a number of coats of full strength dark brown, eventually resulting in a even, but dark, dye job. Any comments or suggestions will be greatly appreciated. Jeff Quote
Lobo Posted February 21, 2010 Report Posted February 21, 2010 Working with the brown dyes has caused me more than a few incidents of grief. I believe that immersion dying is needed so that minor surface abrasions won't expose the underlying fibers. I also use neatsfoot oil on all finished products, which dramatically darkens just about any dye shade I have tried. I still use immersion dying following the forming process. Using Fiebing's spirit-based dyes diluted with isopropyl alchohol, I dip each piece very briefly (about 5 seconds), then place it onto a drying rack. Depending on temperatures in the shop, the alcohol has evaporated off and the dye has set to a point where the piece can be handled within 20 to 45 minutes. Any signs of uneven dye penetration are readily visible, and a second very brief dip (or quick swabbing with dye solution) can be done easily. Making sets of items can be a real challenge. A holster of 8-oz. veg-tan from one hide, a pouch of 6-oz. veg-tan from another hide, and a belt of 9-10 oz. veg-tan from a third hide, all of these will respond a little differently to the dye solution, so a little time and attention is needed. I usually do all of my dying at one time, frequently over a couple of hours during an evening, and I take a 6-pack of beer into the shop to entertain myself while drying periods are completed. Then, after a day or so, I do my oiling. I have learned to go slowly with that, using a paintbrush to apply the oil moderately and buffing with a towel. This is especially so on sets (as described above). I very much like the highlights provided by this method, finding the result much more natural looking than any even coating and resulting plastic-like effect. It has been a period of trial and error for me, learning to do controlled applications of the browns and achieve consistent results. There is nothing wrong with pre-dying your cut pieces prior to assembly, sewing, forming, etc, and I am now experimenting with that method for a planned new color (more in the russet/saddle tan range, which has proven very difficult to reproduce with my current methods for black and cordovan brown). I expect to find a few more challenges in this business any time now. Quote Lobo Gun Leather serious equipment for serious business, since 1972 www.lobogunleather.com
Members JeffGC Posted February 22, 2010 Members Report Posted February 22, 2010 Working with the brown dyes has caused me more than a few incidents of grief. I believe that immersion dying is needed so that minor surface abrasions won't expose the underlying fibers. I also use neatsfoot oil on all finished products, which dramatically darkens just about any dye shade I have tried. I still use immersion dying following the forming process. Using Fiebing's spirit-based dyes diluted with isopropyl alchohol, I dip each piece very briefly (about 5 seconds), then place it onto a drying rack. Depending on temperatures in the shop, the alcohol has evaporated off and the dye has set to a point where the piece can be handled within 20 to 45 minutes. Any signs of uneven dye penetration are readily visible, and a second very brief dip (or quick swabbing with dye solution) can be done easily. Making sets of items can be a real challenge. A holster of 8-oz. veg-tan from one hide, a pouch of 6-oz. veg-tan from another hide, and a belt of 9-10 oz. veg-tan from a third hide, all of these will respond a little differently to the dye solution, so a little time and attention is needed. I usually do all of my dying at one time, frequently over a couple of hours during an evening, and I take a 6-pack of beer into the shop to entertain myself while drying periods are completed. Then, after a day or so, I do my oiling. I have learned to go slowly with that, using a paintbrush to apply the oil moderately and buffing with a towel. This is especially so on sets (as described above). I very much like the highlights provided by this method, finding the result much more natural looking than any even coating and resulting plastic-like effect. It has been a period of trial and error for me, learning to do controlled applications of the browns and achieve consistent results. There is nothing wrong with pre-dying your cut pieces prior to assembly, sewing, forming, etc, and I am now experimenting with that method for a planned new color (more in the russet/saddle tan range, which has proven very difficult to reproduce with my current methods for black and cordovan brown). I expect to find a few more challenges in this business any time now. Thanks for the detailed explanation of your process. Jeff Quote
Members Rhome Posted February 22, 2010 Members Report Posted February 22, 2010 Hi, Browns can be a problem. For me I use Angelus dyes, I believe it is the color Spice for my browns. I had a conversation with the late great Lou Alessi and asked him how he gets such a beautiful even brown on his holsters. he told me that 1st he simply dips the leather in the dye. 2nd he sews the holster and forms it. 3rd he will re-dip the holster if needed. So far that simple method has worked out great for me. And I only do it that way with the brown colors. Every other color I just dip dye the holster when I'm done forming and drying it. I hope this helps. Best, Rhome DGL Quote www.desbiensgunleather.com
Members mattsh Posted February 23, 2010 Members Report Posted February 23, 2010 I have to agree with Rhome. In years past Lou was a great tutor and he told me the same thing. He always did the dye before forming and did it by dipping. Since I have not purchased enough dye to do dipping I simply spray brown, which my current project is the first one I have actually done with the intent of using brown and spraying has worked wonderfully. In the past I have always done black simply because I could not get brown to do what I wanted. Quote "Courage brother, do not stumble, though thy path be dark as night: There is a star to guide the humble, trust in God, and do the right. Let the road be dark and dreary and its end far out of sight. Face it bravely, strong or weary. Trust God, and do the right." - General Norman Schwarzkopf
