Members Toddo Posted March 18, 2010 Members Report Posted March 18, 2010 I have this wallet I'm making for my sons birthday. I'm pretty much done with the tooling and painting. I need some advice on the finishing. Here's the wallet: Should I die the background? Obviously it would have to be a light tint of whatever color so that the dark red lettering would not get lost. The paint is just ordinary cheap acrylic paint I got at the art store. I put it on in layers. First layers watered down a lot and built from there. Then I flexed the leather while it was drying so that it would not crack after drying. It seems to have worked. I can bend it all around with no cracks. If I were to dye the background, then I would need some kind of mask product to block the dye from getting on the painted areas. What should I use if I decide to dye it? And... when dying, do you use a wide sponge brush so that it comes out even? Or just use a cloth. And do you dye it like wood? Meaning, do you make a pass with the dye, then go back and make a pass with a dry cloth to sort of even it out? Then after dying, what product should I use to seal it? I have this Eco Flo stuff that came with my sons beginner kit that's called super shene. Is that stuff compatible with the acrylic paint? I mean, what's the best thing to use so that it will be completely protected and the paint will never rub off through a lot of use? By the way, I have a beginners tip for anyone who accidently gets a dark water spot on their project. When I was painting the lettering, I got a tiny bit of paint out of the paint area (look directly under the letter K). I tried to get it up with a wet q-tip. It seemed to smear and then I tried a wet cloth. Well, let me tell you, it got out of hand big time. I then went and got a little bleach and water mixture and tried that. I finally got it to where it looked like there was no red tint on the leather anymore. But the area got soaked through with a big spot. The next day after it dryed there was a big dark spot. I was mortified. I tried to put straight bleach on it to get it out. No good. I even tried to put this product called "oops" on it to try to get the dark spot out. No go. So I called the Tandy shop near me and asked how to get rid of a dark water spot. The guy there says there's nothing you can do, once it's in there, it's in there. A lot of help that guy was. I tried to google up some answeres and the best thing I could find is that I should re-wet all the leather and then it dry. So I took the thing and just soaked it. Held it under water for like 5 minutes, the entire piece, front and back until it was completely saturated. After that, I let it sit a while and then I could still see a bit of a dark spot there. Eeek! Well then I thought I could just take off a little top leather with a piece of sand paper. Like maybe kind of errase it. It worked! I used to rough of sand paper though. I only had #100 grit paper handy. It did take the spot out though. Now it looks as though it's actually a little lighter in that area than the rest. Better than a dark spot though. I must have took off the tanage or something. I only used the sand paper when it was soaking wet. I don't know if this method would work while it is dry. So check: water spot - remove by wetting leather, then rub with find grain sandpaper until gone. Quote
dirtclod Posted March 18, 2010 Report Posted March 18, 2010 Nice job !! I would of never seen the spot if you hadn't pointed it out. I generally use resolene for a finish and some times saddlelac. Bad thing about the saddlelac is after you use it a couple of time it seems to want to splatter because the spreyer gets junk in it and i never have been able to get clean. You boy is gonna love it. Quote I'm old enough to know that i don't know everything.
Members Toddo Posted March 18, 2010 Author Members Report Posted March 18, 2010 On 3/18/2010 at 1:30 AM, dirtclod said: Nice job !! I would of never seen the spot if you hadn't pointed it out. I generally use resolene for a finish and some times saddlelac. Bad thing about the saddlelac is after you use it a couple of time it seems to want to splatter because the spreyer gets junk in it and i never have been able to get clean. You boy is gonna love it. Thanks dirtclod! I assume Tandy has got the resolene. I'll give em a call tommorrow and ask them. I guess I'm leaning more towards not dying the background because of the dark lettering. I got plenty o' time to decide. Quote
Members Penden Posted March 18, 2010 Members Report Posted March 18, 2010 It's my understanding that resolene is very similar to acrylic paint so I agree that that would be your best bet Quote
Ambassador Luke Hatley Posted March 18, 2010 Ambassador Report Posted March 18, 2010 On 3/18/2010 at 2:05 AM, Toddo said: Thanks dirtclod! I assume Tandy has got the resolene. I'll give em a call tommorrow and ask them. I guess I'm leaning more towards not dying the background because of the dark lettering. I got plenty o' time to decide. For a finish i use Satin Sheen , it works for me. Lace or sew the bilfold and put it to good use.your son will love it for a long time. untill he looses it, mine lost 2.... Quote Luke
electrathon Posted March 18, 2010 Report Posted March 18, 2010 If you dye the background you will likely end up with a splotchy mess. It would be best if you leave it natural. Bachground paint will rub/wear off, so stay away from that too. Also, the spot that you sanded on, it will be a completley differant copor if you try to dye it. Hindsite: If I was going to do a similar wallet and wanted background color I would have first dyed the total piece by dip dying it. You can paint over that and would not have to dye around the tooled area that way. Aaron Quote
Members McJeep Posted March 18, 2010 Members Report Posted March 18, 2010 I think the colour combination works perfect with it being natural. Stitch her, finish coat her, and call her done. Nice work! Quote "I gotta have more cowbell!" Cristopher Walken - SNL
Members Toddo Posted March 19, 2010 Author Members Report Posted March 19, 2010 It's settled then. No dying the backround. Thanks a lot for the advice (and compliments) every one! The more information I get, the better. I actually did make a "splotchy" mess on my fist little project I did. A bookmark that I did a sheridan pattern on. I actually painted the dye on with a tiny brush in order not to get it on the tooled area. Totaly did not come out the way I wanted it to. I'm skittish on dying anything for right now. Quote
