Members rawhide1 Posted April 13, 2010 Members Report Posted April 13, 2010 I was wondering if acrylic paint would bond to clear-lac. The reason I ask is it seems no matter how much I buff a piece I've dyed black the clear-lac will pull some of the black dye onto my paint. Which aint good. So if I clear-lac the piece first and then paint and then clear-lac the whole piece will the paint bond to the clear-lac. Thanks, Mike Quote
Members retiredff Posted November 20, 2014 Members Report Posted November 20, 2014 I know this is an old thread but I would also like to know if acrylic paint will bond to Clear-Lac. If I then apply another coat after using acrylic paint will the Clear-Lac smear or ?? the paint? Thanks Quote
Members Colt W Knight Posted November 20, 2014 Members Report Posted November 20, 2014 (edited) Solvent based lacquer is a porous finish. Lacquer is an evaporative finish, meaning it does not cure chemically, the solvents merely evaporate over time. Because of this, lacquer takes a long time to dry, and the evaporating solvents leave micro pores in the finish. This is why old furniture would get moisture rings when you set drinks on the table top without a coaster. The moisture seeped/absorbs into the pores. Evaporative finishes like lacquer typically do not have recoat windows because the solvents from the fresh lacquer allow the fresh coat to melt/meld into the previous coats. Modern polyurethane finishes(like on cars) actually cure chemically after a short amount of time. If you don't recoat within that drying period, you have to scuff the surface to increase the surface area and provide tooth for the next coat to hold onto. This is what happens when you mix two types of finishes. The two finishes do not bond chemically, they simply stick to the previous substrate like glue-mechanical bond. If there isn't enough surface area for the previous coat to adhere to, they will wear off. The clear lac is most likely a solvent based lacquer, and the paint is most likely a water based acrylic. Can WB acrylic adhere to leather coated with a leather lacquer finish? Maybe, test it and see. Too many variables to say yes or no 100% of the time. In my experience, the leather is porous enough to allow the acrylic to stick without out much problem. Edited November 20, 2014 by Colt W Knight Quote
Members retiredff Posted November 20, 2014 Members Report Posted November 20, 2014 Thanks for the detailed reply Colt. I applied some clear-lac to a test piece a few minutes ago, I will apply some paint after it dries. Thanks again Tony Quote
Members Colt W Knight Posted November 24, 2014 Members Report Posted November 24, 2014 Thanks for the detailed reply Colt. I applied some clear-lac to a test piece a few minutes ago, I will apply some paint after it dries. Thanks again Tony No problem. I spent a lot of time researching paint/finishes when I started building guitars. Finishes are complicated, and modern finishes even more so because they are mixtures of finish types. 60-70 Years ago, lacquer was Nitrocellulose based, and around the 60s, lacquer became Acrylic based. Then the automotive industry came out with Urethanes and polyesters. Then of course there are shellacs, enamels, water based products, and oil based products. Quote
Members retiredff Posted November 24, 2014 Members Report Posted November 24, 2014 colt - the acrylic stuck just fine to the clear-lac, BUT when I applied clear-lac over the paint... what a mess! can u suggest finish to use over the paint? THX Tony Quote
Members Colt W Knight Posted November 25, 2014 Members Report Posted November 25, 2014 What happened? Quote
Members retiredff Posted November 25, 2014 Members Report Posted November 25, 2014 I brushed on the clear-lac over the acrylic paint, the CL dissolved the paint and it smeared. Good thing this was just a test! Tony Quote
Members hornm Posted November 25, 2014 Members Report Posted November 25, 2014 Basically whatever the thinner in the Clear-Lac is, is like paint thinner. I've got both Clear-Lac and Wyoshene (same thing technically). The "obnoxious" smell that they produce is like a Xylene or Toluene(sp?) type thinner. Basically you applied something that is going to "melt" the thin coat of acrylic paint that you put on. If you can spray the Clear-Lac over your paint job that might work since it wouldn't be rubbing across the paint causing the disolved portion to "travel". I couldn't say though as I pretty much stay away from the acrylics paints because of the terrible job I do with them Horn Quote Michael "If the women don't find you handsome, they should at least find you handy" Red Green
Members retiredff Posted November 25, 2014 Members Report Posted November 25, 2014 Horn - I have a airbrush that I want to experiment with, I'll try that, or I may look for something else besides clear-lac as a resist that will work with the acrylic paint. Thanks Tony Quote
