Moderator Art Posted April 17, 2008 Moderator Report Posted April 17, 2008 Hi Milen, I think that machine will work great for you, plenty of room for bag work. The right foot/holster plate combo is a good setup for putting gussets into bags, you lose some capacity (thickness) with the holster plate, but you have a bunch of excess with that machine anyway. Leave the feet stock (unmodified) till you see what your use will be. Judicious use of the grinder can go a long way to making life easier in certain applications, but give it some time. Artisan's are great machines, I put more mileage on mine in a weekend than some folks put in a year/lifetime and they just keep running (800 spm continuous for 32 hours on a weekend, stopping to change bobbins and oil). If you ever have problems, Artisan service is probably the best out there over the phone. Do not hesitate to call Steve if you have a problem, he is great. Art Thank you all. I got YRsaddles's Artisan 4000. I do not do lots of items so it looks like a god fit for me. ART thanks for laying it down for me. Quote For heaven's sakes pilgrim, make yourself a strop!
Members MadTailor Posted April 17, 2008 Author Members Report Posted April 17, 2008 Hi Milen,I think that machine will work great for you, plenty of room for bag work. The right foot/holster plate combo is a good setup for putting gussets into bags, you lose some capacity (thickness) with the holster plate, but you have a bunch of excess with that machine anyway. Leave the feet stock (unmodified) till you see what your use will be. Judicious use of the grinder can go a long way to making life easier in certain applications, but give it some time. Artisan's are great machines, I put more mileage on mine in a weekend than some folks put in a year/lifetime and they just keep running (800 spm continuous for 32 hours on a weekend, stopping to change bobbins and oil). If you ever have problems, Artisan service is probably the best out there over the phone. Do not hesitate to call Steve if you have a problem, he is great. Art Hope so Art. You mentioned changing Oil. .... I guess I'll read the manual first. I'm sure will take some practice to master it, but I'm ready to do the work. Have been in the tailoring trade for over 15 years and any garment machine there is I'm like a race car driver. I'll ask questions soon...... I've seen a video on the web of a dude working on one but did tried to find it again with no luck. Maybe it was not Artisan..... Thanks Art Quote madtailorleather.com https://www.instagram.com/mad_tailor_leather/
Moderator Art Posted April 17, 2008 Moderator Report Posted April 17, 2008 You just oil the big stitchers, you don't change the oil, there are usually no reservoirs or wicks like in smaller machines. I think the videos are from Raphael Sewing up in Montreal. Art Hope so Art. You mentioned changing Oil. .... I guess I'll read the manual first. I'm sure will take some practice to master it, but I'm ready to do the work. Have been in the tailoring trade for over 15 years and any garment machine there is I'm like a race car driver. I'll ask questions soon......I've seen a video on the web of a dude working on one but did tried to find it again with no luck. Maybe it was not Artisan..... Thanks Art Quote For heaven's sakes pilgrim, make yourself a strop!
esantoro Posted April 22, 2008 Report Posted April 22, 2008 Hi Art, How much heavier would you say the 4000p/Highlead is than the 4000R? Ed Hi Mad,There are a few choices for heavy stitchers but I will try to narrow it down a bit. There are new and used, but I will try to keep it to fairly recent vintage and or completely remanufactured units. Criteria: Heavy Machine Castings No belts in drive system except to drive head flywheel Capable of easily stitching 3/4" of Sole Bend Readily Available Parts Needle system is readily available from supply vendors Accessory parts are available to handle most sewing configurations Needle feed (or Awl), Walking foot or Jump foot Drop feed (if important to the application, e.g. blankets, webbing) Cylinder bed or Post bed Adjustable Stitch Length withing range of 4-8spi Thread sizes 207 (Tex-210, Metric 13) to 346 (Tex-350, Metric 8) and 415 (Tex-400, Metric 7) 9" minimum throat size Juki 441 and clones Around in Juki form since the late '70s but available since the mid '90s in clone format from Taiwan and Mainland China. A very reputable machine that in stock format isn't the greatest machine for leather, but with a few modifications to needle plates, presser feet, and feed dogs, and addition of a thread lube pot, turns into one of the primo heavy leather sewing systems. Highlead GA2688-1/Artisan Toro-4000P This is a 441 clone on steroids. Machine casting is much heavier and things are a little beefier, but sewing parts are 441 (which is plenty heavy in it's own right). A 16 1/2 inch throat and high head gives a lot of clearance for most anything. I have both Highlead and the Artisan machines. They come from the Huigong No. 3 factory in Shanghai and are in my opinion, very good machines from an ISO 9001 factory. The Highlead machines come from the factory set up to sew heavy fabric or webbing and run a little over 800spm with a 3/4hp clutch motor. Not exactly your daddies leather stitcher but just what I need for padding contracts I have. Small animals, children, and sane individuals run from the area when I am using it, but you easily get used to it and wish at times it were faster. The Huigong machine as marketed by Artisan as the Toro-4000P is a completely different machine personality-wise. Different feet and needle plates more in tune with leatherwork eliminate most top and bottom marking and the motor drive system with a speed reducer and servo motor will sew a flat out rate of about 180spm and a crawl so slow it can be measured in minutes per stitch if desired. The torque available from the speed reducer really precludes the need for a 3/4hp motor and the 1/2hp provided is more than adequate. The pedestal stand from Artisan, with heavy duty casters makes it easy to move the machine, but it remains very stable platform while sewing. Artisan Toro-4000R/Cowboy CB 441/Ferdco Pro 2000/SewMo 441/and Others When the patents ran on the Juki TSC-441, it wasn't long till they got in line to start knocking it off. Ferdco actually used the Juki 441 as the base for their machine until the patents ran and the Taiwan quality got to the point where they were satisfied with it. Today, all these machines are pretty good. Some are made in Taiwan and some are made in Mainland China, I can't tell which is which. In all, I have used the Artisan, Ferdco, and SewMo and found them very good, I don't think any of them will be better than the Ferdco Juki Pro 2000 (original), but they don't seem to be much worse. Artisan Toro-3000/Ferdco Pro 2020/and Others Take the popular 441 and take 7 inches out of the middle and lose the integral bobbin winder and replace with an external one (off of drive belt), so now you have a 441 clone with a 9 inch throat. These are little brothers to the 441s above. Most are supplied with all three feeds, Needle, Walking foot, and Drop. Changing to non-drop is a matter of taking out the feed dog and strapping on a slotted needle plate. Adler 205-370/Cowboy CB 205-370/SewMo 205-370/probably Others The Adlers and their clones are excellent leather machines and sew really well, but extremely thick stuff is not their best suit. Feet and needle plate variety is not as great as the 441s. They also don't "feel" like they have as much room as the 441s. This is really a German thing, if they make them smaller, they'll go faster and in production these machines scream. If I had a factory, I'd want Adlers or Pfaffs in it. Run like hell, run forever, made of unobtanium. Campbell-Bosworth/Union Lockstitch/Other Needle and Awl These are really great machines, most from yesteryear, but work well in the production environment. I use mine and have it setup to sew linen on holsters and belts. Campbell will machine you whatever part you need to do whatever sewing operation you need, but this is not the machine for the newbie or the faint of heart, especially the Union. Not a big machine in the throat area, but there are few things I have problems with. That's it in a nutshell. Art Quote http://www.waldenbags.com http://www.waldenbags.etsy.com
Moderator Art Posted April 22, 2008 Moderator Report Posted April 22, 2008 Hi Ed, About 25 lbs. Gussets, webbing, and bearing blocks seem a little heavier, like the rest of the 441s, it is not balanced to run over 800spm, at or below 800, it just purrs along. Art Hi Art,How much heavier would you say the 4000p/Highlead is than the 4000R? Ed Quote For heaven's sakes pilgrim, make yourself a strop!
