Members TRICKYRAC Posted May 13, 2010 Members Report Posted May 13, 2010 I am new to leather working and have a done a few small projects for myself and have pretty much figured out most of the basics. Now I need some advice to clean up the rough edges on my work. My main question is, what is the best way/tool to use to cut my patterns out? Right now I am using a utility knife that the bends and cuts my leather at an angle when I cut around corners. I want to learn how to cut a pattern and have smooth round corners and have the whole thing smooth and straight when I get done. Any help and advice will be greatly appreciated. Thanks in advance. Quote
mike59 Posted May 13, 2010 Report Posted May 13, 2010 On 5/13/2010 at 6:23 PM, TRICKYRAC said: I am new to leather working and have a done a few small projects for myself and have pretty much figured out most of the basics. Now I need some advice to clean up the rough edges on my work. My main question is, what is the best way/tool to use to cut my patterns out? Right now I am using a utility knife that the bends and cuts my leather at an angle when I cut around corners. I want to learn how to cut a pattern and have smooth round corners and have the whole thing smooth and straight when I get done. Any help and advice will be greatly appreciated. Thanks in advance. Are you certain that your utilty knife blade is bending? If so, you are either applying way too much pressure down, or you need to buy a better knife, and, or better blades. It may be that when you are cutting around corners you are actually leaning your knife away from the leathers edge, afraid of cutting off of the scribed line. Most beginners do this. You have to keep the blade of whatever knife you use, at a 90 degree angle to the cutting surface all of the time. Practice and being cognizant of your cuttting angle will be the best teacher. Hope it helps. Quote
Members TRICKYRAC Posted May 14, 2010 Author Members Report Posted May 14, 2010 Thanks for the tip. I know the blade is bending, cause I can see it bend, but like you said, I am probably putting too much pressure on it. The only thing about that is it seems like the leather won't cut unless I put a lot of pressure on it. I am just using an exacto knife. Should I use a better/bigger knife? Thanks again. Quote
Ambassador Luke Hatley Posted May 14, 2010 Ambassador Report Posted May 14, 2010 On 5/14/2010 at 12:25 AM, TRICKYRAC said: Thanks for the tip. I know the blade is bending, cause I can see it bend, but like you said, I am probably putting too much pressure on it. The only thing about that is it seems like the leather won't cut unless I put a lot of pressure on it. I am just using an exacto knife. Should I use a better/bigger knife? Thanks again. I like using an exacto knife also .....but only on thin leather. Get a Stanley knife they have super sharpe blades, i beleive you will like it better. Quote Luke
Members Tkleather1 Posted May 14, 2010 Members Report Posted May 14, 2010 I prefer a round knife personally. Quote Tim Worley TK-Leather If you don't ask and dont try how are you gonna learn anything?
Members Meleck Posted May 14, 2010 Members Report Posted May 14, 2010 If you have to press hard on the blade to cut through leather, I figure it's because your knife isn't sharp enough. I've cut through 10oz vegetable tanned leather with an exacto knife with no problem. It was strooped before hand and I'll stroop as soon as the knife doesn't cut clean. A strooping board here is your best friend. They are easy to make and are worth 10 times their cost. Quote
Members TRICKYRAC Posted May 14, 2010 Author Members Report Posted May 14, 2010 Thank you all for the replies!!! Let me ask this... Does the leather need to be cased before I cut it, or should it be dry? Quote
Ambassador Luke Hatley Posted May 14, 2010 Ambassador Report Posted May 14, 2010 On 5/14/2010 at 3:21 PM, TRICKYRAC said: Thank you all for the replies!!! Let me ask this... Does the leather need to be cased before I cut it, or should it be dry? sometimes....if the leather is cased it is going to get Marked UP more than you want it to be. you'll just have to experiment......... Quote Luke
Members katsass Posted May 14, 2010 Members Report Posted May 14, 2010 On 5/13/2010 at 6:23 PM, TRICKYRAC said: I am new to leather working and have a done a few small projects for myself and have pretty much figured out most of the basics. Now I need some advice to clean up the rough edges on my work. My main question is, what is the best way/tool to use to cut my patterns out? Right now I am using a utility knife that the bends and cuts my leather at an angle when I cut around corners. I want to learn how to cut a pattern and have smooth round corners and have the whole thing smooth and straight when I get done. Any help and advice will be greatly appreciated. Thanks in advance. TRICKYRAC, I do things a little differently than most...but it works well for me. I first transfer my pattern to cased leather with a ball point stylus. Next I use a swivel knife with a filigree blade to enhance the marks from the stylus...it won't cut through the full thickness of leather, BUT, it gives me an exact line to follow with a 'dedicated' knife (one that is used to only cut leather). I finally cut out the pattern following in the impression made by the swivel knife. A couple of pics of my tools used. The 'dedicated knife is a "Murphy" knife and is about 70 yrs old. Mike Quote NOTE TO SELF: Never try to hold a cat and an operating Dust buster at the same time!! At my age I find that I can live without sex..........but not without my glasses. Being old has an advantage.......nobody expects me to do anything in a hurry.
