in the posts last week about pictures of different shops and how they are set up I saw a picture of a clicker that could easily be duplicated if a person has some metal working tools and a welder. the poster's name was Randyc. I also believe that Weaver leather has one like that in their catalog. I hope this helps I too have run into the problem of not being able to cut out a lot of parts for a product I make and am looking for a similar clicker. good luck
Harbor Freight Tools is your best friend for making your own clicker.
I'm going to let the cat out of the bag for making cheap clicker dies- Banding stock.
Banding Stock + Hardwood Shapes + Sheet Metal Screws = Some pretty elaborate dies that can last for quite sometime. You can sharpen the banding stock (free if you look for it) with a simple set up, Ive even done it with a dremel.
Cut the shape from a good dry hardwood. (I use 1 1/4" for 1 1/2" banding, 1 3/4" for 2" banding)
I leave approximately 1/4" give or take depending on my needs for the leather.
I cut 1/2" holes in the block for push out pegs (I use a standard configuration so I can put these pegs in a bench and turn the die upside down and press the leather out)
The banding is attached to the block by predrilling holes for the screws as needed. Ive gotten 100 or so before sharpening. In some cases, I just pop new sharpened stock on and get back to it...
The rest is self explanatory, I hope... :whistle:
- Alcove Leather & Crafts
"The Unique Leather Supply Store"
"Ask your supplier where their stuff comes from!"
  • 2 years later...
I know this is an old thread, but figured i'd put my 2 cents in on it.. Look around on craigslist and the classified section of the local newspaper. I just picked up a 30 ton manual hydraulic shop press for like $150 and its in like new condition. all I am going to need to do to make it functional is to make up a top and bottom plate for it and get some HDPE (high density polyethelyne) white board (like cutting board material) and it will be ready to go. most local small welding shops can put something together pretty easy for whatever the size you get is.
After I have made it pay for itself a few times, I will probably swap the manual bottle jack out with an air assist or a fully air activated jack so I can control it with a couple of foot pedals. That will cost more than the whole press, but even with all that, I will still have less into it than most of the regular clickers that only have a 18x24" cutting/embossing area.
Just a though. now on to figuring out cheap dies...
My setup is a $149 12T press from Northern Tool. I've got a 12"x12" HDPE sitting on top of a steel plate. And another steel plate I put on top of the die when I get it in position. I have not modified the ram rod as I still want to be able to use it as a press if I need too (it is in my garage and I do work on my truck) ;)
What I'll probably do after I get my welder is build different crossbeam that sits under the ram.
My setup is a $149 12T press from Northern Tool. I've got a 12"x12" HDPE sitting on top of a steel plate. And another steel plate I put on top of the die when I get it in position. I have not modified the ram rod as I still want to be able to use it as a press if I need too (it is in my garage and I do work on my truck) wink.gif
Monica, I have seen that press in the northern catalog and have come close to buying it but I still have not found a source of dies that I can afford, my problem is that our product line being mostly custom and covering saddlery and gun leather as well I don't get to replicate items that often. Who do you get your dies from? I think I might try that process of makeing dies out of banding stock like alcoveshop suggests above...... Jeff
Horsewreck, aka, Jeff M. Hairgrove
Jeff, I've just started to order dies, one by one. I've ordered from Texas Custom Dies. They make a nice die though I have not ordered yet my regular holster patterns. I'm currently waiting for a reply on one of my fullsize patterns as I mail it in (no fax and I don't trust email for patterns).
I saw the DIY above and I'm interested in trying it myself to see what comes out. Biggest question I have on it is if the metal band stays strong and sturdy enough not to warp over repeated presses.
Monica, I will check out TX Custom Dies. Ditto on your concern about metal band holding shape but I may try it just to see. Thanks......
Figured I would put my 2 cents in... I just ordered 2 dies this week from Tippmann Industrial here in Indiana. one is a violin shaped flask for re-enactors, the other in a strap cut out for making a mug strap for hanging your cup or whatever else from your belt. The 2 of them combined were like $165 with about a week turn around (should be here monday).
For more simple shapes, I have talked to a local metal fabrication place (small 1 man shop) that is going to do some of the more simple designs for me, and is helping me get the plates for my press put together.
As for the "metal banding" do it yourself dies, I have been told that the key to it is to only allow enough metal outside to cut thru the leather and a couple Millimeters to go into the cuting pad. the rest should be supported and locked into the plywood top. I have a friend of mine that does work on CNC machines for a place that makes all their own dies using that method for cutting out plastic/paper/leather templates and gets anywhere from 100-200 pieces before having to replace it. if its something they use alot, the DIY makes them enough money to send off to have a die professionaly made (or several ;).
If I had more time and space to do them myself, that would be the way to go (and probably will for the next couple due to size and cost of what I want to get made)
Vince
Just an update, plus a question.
My order is in and being built for one of my fullsize patterns at Texas Custom Die. It's running $60 (plus shipping). I think that's reasonable.
As for the question, I've got a bunch of this garden metal edging I'm about to pull up. Can that material be used instead of new metal banding? Just curious. I figure while I've got the stuff might as well experiment.
Also, where do you buy metal banding from? Do they just have that at home depot or the like?
