alpha2 Posted February 18, 2017 Report Posted February 18, 2017 That tool is not an option if your stitching isn't all on an edge. Like the pancake holster I did today for my 1911. Quote So much leather...so little time.
Members LeatherBeast Posted February 20, 2017 Members Report Posted February 20, 2017 Fineleatherworking.com has a lot of the Blanchard products. I use their diamond point awls and pricking irons. The Blanchard awl cuts through like butter. Check out my tool guide here. Quote Sign up for the FREE beginner leatherworking mini-course at www.leatherbeast.com
Members ContactCement Posted May 12, 2017 Members Report Posted May 12, 2017 (edited) Torture stick. I nearly stuck my finger with an awl haft the other day not to mention the holes left were undesirable and inconsistent (my fault) I now use a very simple modern tool which is the single tooth Craftool Pro Fine Diamond Awl 88057-01 and it works great when used with the Craftool Spacer Set 8091-0 If your really dedicated to using an awl haft and handy with a hammer and propane torch go get some inexpensive drill rod or tool steel. Heat it, pound it then quench it in light weight motor oil then sharpen. Edited May 12, 2017 by ContactCement Quote
480volt Posted May 12, 2017 Report Posted May 12, 2017 Buy a Bob Douglas slim awl blade. Buy a Douglas or Barry King awl handle. Bob's awl blades come sharp and are polished to a mirror finish, you should own one if only to give you a reference on what a well finished one should look like. Eventually, he will retire and you will kick yourself for never acquiring one. On the downside, his blade and handle combo will likely be longer than what you are used to. Other members here have suggested snapping off the blade to shorten it, I just reserve it for heavy work. I use a well sharpened and polished Tandy awl for lighter stuff, the small handle is easy to palm, and the recess at the top left from the lathe center is good for getting the needles started on that tough stuff. Quote
