Members lwoirhaye Posted June 28, 2010 Members Report Posted June 28, 2010 Hi folks. Can anybody tell me what the correct needle length is for the 29k machines? I'm yet another of those nutcases battling a 29k. It's a 29k60 long arm patcher. It's a beautiful machine and I stubbornly believe in its potential. Based on many factors I think it needs TLC, but is far from knackered. When I first got it I went to a local upholstery shop to get the correct thread and needles. The people were nice but their English was a little sketchy. After all my diagnosis I've discovered that I have needles in the wrong system. I believe they are too long by a small amount. They sold me needles for walking-foot upholstery machines, but these are, I've now surmised, a slightly different length than 29k system needles. I'm pretty handy and I would like to cut down one of my needles to determine if the needle length is the source of the problem. I measured the needles I have with a dial caliper. They are in the 1.720" range. I've learned a great deal from posts here about the 29k machines, so thanks to all who share their knowledge here. Quote
CowboyBob Posted June 28, 2010 Report Posted June 28, 2010 They use 29x3 or 29x4,they probably sold you 135x17 which is also the same length approx 1.75" long,what problems are you having with it? Bob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members lwoirhaye Posted June 28, 2010 Author Members Report Posted June 28, 2010 They use 29x3 or 29x4,they probably sold you 135x17 which is also the same length approx 1.75" long,what problems are you having with it? Bob Ok. 135x17 is correct. The upper thread is birdnesting, getting pulled down under the shuttle carrier where it wraps around the shaft the carrier pivots on. My understanding is the thread is supposed to go around the shuttle, pulling the loop underneath the shuttle. My theory was that the needles were too long and the thread was being pushed too low at bottom of the stroke. Quote
