well theres no need to get upset. i've always been interested in leather upholstery. i spoke with a local upholstery shop and he advised me to buy an old iron/steel looking sewing machine to sew leather. i checked craigslist locally and came across this machine rather cheap. i found a video of it 'sewing" leather on youtube so i purchased it. I have no problem
with upgrading to a better machine i was just curious if could possibly use this machine. With that in mind what machine do you guys recommend for sewing leather in the
range from uphosletry to 1/4 thick?
Whoa, sorry if I came off as negative or upset in any way. Not my intention at all, and I'm very glad to see you having success with your machine. I'm just trying to be helpful and useful.
Industrial sewing and cutting, parts sales and service, family owned since 1977, Philadelphia, Pennsylvania USA, 215/922.6900 info@keysew.com www.keysew.com
  • Replies 39
  • Created
  • Last Reply
Top Posters In This Topic
No worries
  • 2 weeks later...
Quick question. If I install a roller foot, do I have to install a new lower plate? Also I was playing with the tension and when I attempt to sew the thread on the bobbin doesn't sew tight. It's very loose. Is that my bobbin tension that is to loose or is it my tension?
If you install the flat foot with steel rollers inside it you will not have to change the feed dog or cover plate. If you install the actual big rolling wheel, that replaces the pressor foot, you will need the matching single row feed dog and single slot cover plate. These are usually, but not always, sold as a set online. If you intend to use the machine exclusively for leather garments and chaps, a true roller foot set is a must. The wheels are usually available in two diameters. Get the bigger diameter, which is about 1 inch. Bob Kovar, at Toledo Industrial Sewing Machines sells the roller foot conversion set.
If you are going to sew a variety of projects, including cloth upholstery, go with a flat foot that has inside rollers protruding from the bottom.
As for the poor bottom tension, the cause and answer depends on the type and size of thread you are trying to use, which you did not state. Here are some basics that will affect the bottom stitch appearance.
  • If the bottom tension is too loose the knots may appear on the top of the work.
  • If the bottom tension is too tight, the knots will appear under the work.
  • If the knots are being pulled into the layers, but the stitches are loose on the bottom, too much thread is being released by the bobbin. Tighten the bobbin pressure spring one turn.
  • Try reversing the bobbin, so it feeds against the rotation of the shuttle. This is standard practice to avoid bobbins spinning after the machine slows or stops, thus emptying thread into the shuttle without tension.
  • Buy a bobbin case that has an "anti-backlash" spring inside it. This cures the previous situation.
  • If tightening the bobbin spring cures the loose bottom stitches, but pulls the knots down too far, add top tension until the knots rise inside the layers.
The size of your needle can also affect the placement of the knots. If the needle is too small, knots will tend to be on the bottom. If the needle is too big the knots may appear on or near the top. You want the right size needle that feeds the thread without being too loose or to tight. If the top and bottom thread are the same size and the work is dense, go up one needle size, to account for twice the thread thickness in the knots. If you run out of available needle sizes, go down one size in thread, at least in the bobbin.
One thing you must keep in mind is that you bought a garment sewing machine. It is not designed or provisioned for properly sewing heavy nylon thread into dense leather.
Edited by Wizcrafts
Posted IMHO, by Wiz
  • 2 weeks later...
well i got some progress. I took my machine to downtown l.a. to a sewing machine store. I had them install roller foot with plates, new hook, diamond point needle and feed dog. i also had them dial in the tension and basically renew anything that needed to be renewed. i paid 100. was that too much?
Sounds like you got a Great deal :)
Did you go to Orange county industrial like I suggested?
My offer still stands if you would like to come for a visit.
Best of luck,
Al
Al Bane<br />Al Bane For Leather<br />818 209 7945 <br />www.myspace.com/albaneforleather<br />www.facebook.com/albaneforleather<br />www.albaneforleather.etsy.com
i did go to orange county industrial good people good service. i actually dropped the machine at a place called atlas levy in downtown la.
  • 4 weeks later...
well i was sewing some leather and i got a bunch of excess thread caught in the bobbin case under the feed dogs. i removed the feed dogs and removed all the excess thread. Now when i got to sew it seems like
the feed dogs dont pull in the material. i believe my timing is off. Can i adjust the timing myself or should i take it to a shop?
Why don't you take the head back to Atlas Levy and ask to watch the repair man as he resets the timing? That way, you won't have to keep paying them every time you knock out the timing.
Posted IMHO, by Wiz
Hi I saw this and I wanted to share a great thing I use to teach people to sew...do not thread the machine...practice with it without thread or bobbin until you can control the speed. I advise sew in a quiet place no music or noise and barefoot.... learn to hear and feel the motor. I also suggest before you put any foot pressure on the pedal have your hand on the hand wheel and pull forward gently as you give the motor juice... You may have to do this for a while but use scrap leather to practice control and get a feel for the machine. I had to teach myself on my Singer industrial as I had no one to teach me... but I had been sewing on all other types for years so I learned quick enough... You will learn the sound of the motor starting to pull and you can make the machine walk WAY slower than the controllers will and still have fast when you want it! I do top stitched details on mine with hard curves and such so trust that it can be done.... Have fun!
