I actually rooned it, did the whole bathing thing, then let it dry overnight. Then I assembled it, stitched it, then it sat again overnight. Then I soaked it in water and tried to form it - about 2 days after having rooned it. Or should I say "ruined" it, as the case may be! LOL
This was a tooled holster for a customer that's getting married and I'm against a deadline. Shouldn't have tried something new with this one. Live and learn!
First off, vinegaroon isn't a magic solution- dip and presto! There's a few things that need to be done that are only learned by doing. Bitone's batch, Particle's batch and my batch are all a little bit different, and we aren't using the same piece of leather. Also, the 'roon gets better as it ages. My 'roon is at least a year old and I've dropped additional metal in the jar from time to time. As it sits, I can dunk a piece of leather, have it turn black inside 2 minutes, and in 15 minutes there's no smell. The 'roon gets better with age, provided you add enough metal to the brew to completely use up the acid. Ever notice how the vinegarroon smells like vinegar? Keep adding metal to completely reduce the acetic acid (vinegar), and you 'use up' all the stuff making the smell. You also need to give it time. Yes it works after two weeks, but there's still too much acetic acid floating in the brew; so....it smells.
Wet forming should be done while it's wet with 'roon. After forming, toss it in an oven to set it. I use a countertop convection oven, set at 140-150 ish, for about 10 minutes. Then I pull the gun/block from the inside and get it somewhere with moving air. You can place a piece of metal, or even a chilled paper towel inside the holster and it will help pick up the 'sweat' on the inside to speed up drying. Be sure to wipe/replace it from time to time. Once the leather dries, it's somewhat difficult to re-wet, short of total submersion....and even that doesn't work that well.
Here's why- The penetration of the ferric acetate into the leather, seems to push the natural oils and waxes to the surface. That's one of the reasons to oil/condition it after 'rooning. Besides turning black, the piece now acts like you've worked a lot of wax into the surface of the leather- it doesn't want to take moisture. This even effects the flesh side of the leather. As far as stitching.....I use waxed linen thread and hand stitch all my stuff. I haven't had any problems with the vinegaroon discoloring it. Though I don't usually use white thread on black leather, either. The stuff you see dripping off/ soaking off into a towel/rag/etc. is basically 'leather juice', that contains some of the tannins that are displaced. The ferric acetate is still reacting with the tannins, so it comes off as slightly black/blue.
NOTE: When wet molding a 'rooned holster, be sure to either (A) use a blue gun, or (B) thoroughly protect the gun. With some of the finishes available, you won't likely see any damage, BUT what about the insides, where there's some drips? I've had to move 'add snaps' (or any other metal hardware) to the end of the assembly list because the 'roon will eat them if it gets on them while wet. Unless you just enjoy refinishing a weapon, don't risk it- especially with a blued finish. It WILL eat the blueing right off, and a good hot blueing (or re-blueing) isn't cheap.
Give the brew some time to season, I think you'll like it more when it's aged a bit.
Mike DeLoach
Man, thank you very much twinoaks, this is what I have been looking for this whole time, and I think you found my problem, I didn't let it age long enough and didn't use enough metal, I used three full brillo pads to one gallon and as soon as it dissolved, I dipped them, it was about two weeks total wait time, I will add some more pads when I get home, I think that may take the smell away and after some aging.
Twinoaks do you think you can write alittle more on the process after the roon'ing like the baking soda bath etc. and make it a sticky, I tried so hard to find out and research what you said and I think it could benefit others. Thanks again for your expertise on the subject
Ben
  • Ambassador
Bitone40.......if you did what you said you did..you dont use Brillo Pads....
use STEEL WOOL PADS.......Brillo pads has soap in them.
Luke
X
I stand corrected, I did not use brillo pads, they were the fine 0000 gauge , and one course 00 steel wool pads, I made sure not to use the one with soap, which my wife uses around the house , sorry for the confusion
Ben
I'll see what I can do, but as far as calling my little bit 'o knowledge expertise......long way off. I'm too 'green' to be an expert :) There's probably 40 pages worth of discussion on just vinegaroon and it's uses. It gets pretty detailed with alternate formulas, chemical analysis, etc. Most of it came from much more knowledgeable members than me. Still, I'll see if I can dig up a bit of info on it- maybe get links to all the threads in one place.
Mike DeLoach
