Members Shorts Posted April 21, 2008 Members Report Posted April 21, 2008 I'm wanting to purchase a punch badly. Up to this point I do the punch two holes and then clutch out the center with a straight edge. But I'm getting tired of that and think I could make much cleaner holes using a (oval? oblong?) punch. What do you use? I make my slots at 1.5" size. Quote
Ambassador Luke Hatley Posted April 21, 2008 Ambassador Report Posted April 21, 2008 Shorts an 1 1/2" Bag punch is what to get. Quote Luke
Members Shorts Posted April 21, 2008 Author Members Report Posted April 21, 2008 I'm wanting to purchase a punch badly. Up to this point I do the punch two holes and then clutch out the center with a straight edge. But I'm getting tired of that and think I could make much cleaner holes using a (oval? oblong?) punch.What do you use? I make my slots at 1.5" size. My my my, "clutch out"? Guess who has bikes on the brain? Thanks Luke, I've seen them and will probably take the plunge. I was surprised to see they're fairly expensive for a punch, but I guess its that darn good Quote
Members paris3200 Posted April 21, 2008 Members Report Posted April 21, 2008 I seem to recall on another forum that the bag punches weren't wide enough to put a double thickness concealed carry belt through. Might want to try one out before you spend the money on something that doesn't work. Jason Quote http://www.parisleatherworks.com
Members Shorts Posted April 21, 2008 Author Members Report Posted April 21, 2008 I seem to recall on another forum that the bag punches weren't wide enough to put a double thickness concealed carry belt through. Might want to try one out before you spend the money on something that doesn't work. Jason That concern has surfaced. I keep seeing the slots only 1/8" wide. I make mine 3/8" for a single layer belt (a full 1/2" with the edge beveled). Quote
Members Srigs Posted April 22, 2008 Members Report Posted April 22, 2008 I use a half moon wood working cutting tool to cut the top and bottom and then cut between the two points. Works very well for me. Quote Srigs, http://www.sideguardholsters.com "If everyone is thinking alike, then somebody isn't thinking" - George S. Patton.
Moderator bruce johnson Posted April 22, 2008 Moderator Report Posted April 22, 2008 That concern has surfaced. I keep seeing the slots only 1/8" wide. I make mine 3/8" for a single layer belt (a full 1/2" with the edge beveled). If you have enough of them to cut and they are the same size, then maybe contact a die maker and have a die made up in that size. Most can weld a handle on for you. I recall in one thread that a quote for a handle die from (I think) Texas Custom Dies was pretty reasonable. I have had good experiences with what I got from them, and from people I have referred to them too. I saw a slot punch in a shop that a guy had made up to cut the arched slots for the flatter (pancake?) holsters. Looked pretty handy for that cutting job. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Contributing Member Jordan Posted April 22, 2008 Contributing Member Report Posted April 22, 2008 Many ways to skin a cat so to speak, If you make enough money from your products then having a punch or two made is the way to go. If not, then it's hole punch and razorknife time, harder to master than smackin a punch, takes lots of practice for me to get good looking slots. Quote
Members Shorts Posted April 22, 2008 Author Members Report Posted April 22, 2008 Unfortunately on the metalfab side of the house, I don't have a box here But back home I probably can get Dad to put a little gum to the metal and get what I need. Besides, if it gets him more and nicer holsters, why not, right? :D Quote
Members gary Posted April 23, 2008 Members Report Posted April 23, 2008 I use bag or crew punches for run-of-the-mill belt slots but if someone needs a wider or longer slot I use a hole punch twice (I have a set of hole punches up to 1/2" diameter) and then join them using a woodworker's chisel to cut out the slot. It gives a lot more flexibility in slot width and length and, once you've practised a bit, gives a quicker result than using a knife. If I was doing a whol;e lot of one size, however, I'd invest in a specific punch. Gary Quote
