I want to make a nice belt for my wife. For a nice womens belt, I think it would be best if it was made with a curve shape instead of striaght, so the belt would follow the curve of her hips.
How would I go about making a nice cirved cut though? I'm stumped!
Any good methods you use?
I would say just make it straight and let her wear it....Almost all of my belts have gained a slight curve through normal use, but then again im not a woman.....i just dont think ive ever seen someone make a curved belt for that reason, either mens or womens
Tandy used to have patterns for curved waist belts.
You could always use heavier paper, muslin to make a pattern. Cut a strip, wrap it around her, and trim to fit. Clean up the edges, and you have a pattern.
You laugh at me because I am different. I laugh at you because you are all the same.
  • Ambassador
There is no need to cut the belt in a curve shape ....Just wet the belt blank and shape it to the
curve and let it dry.
Luke
Bianchi used to sell one. I bought one for myself even. It for sure came curved. I'm not sure why, but it did. It was their fancy stitched belt.
I can make it straight and see how that works out. It's not like she has giant hips or anything. She is 5'6 and about 120# soakin wet.
Edited to add: I guess Bianchi still makes it. Here is the link....
http://www.copquest.com/14-1800.htm#Bianchi_B21_Countour_Belt_-_1-3/4_inch
Edited by ShortBBL
That is totally different than the ones I was thinking of. Tandy's old ones had a larger section in the back similar to a weight belt that was tooled. Kind of like taking a corset, and cutting the bottom off of it.
Take a flexible aluminum 48 inch rule, . . . bend it so it flexes about 6 inches in the middle (looks like a 48 inch Robin Hood bow). Tape a string to it at each end so you can keep the bow in it.
Trace that bow on a large piece of brown wrapping paper or something similar. Set your pencil divider/compass at the width of the belt and trace outside of the first line the width of the belt, . . . cut this out and see how it fits for your pattern.
You may have to flex it deeper than 6 inches or less, . . . to get the effect you want. This is the John Bianchi technique for getting the right cut on one of his Western gun belts.
May God bless,
Dwight
www.dwightsgunleather.com
LOVE this site!!
Thanks for the help Dwight! That is a very good method and an easy one as well. You rock!
:You_Rock_Emoticon: :You_Rock_Emoticon: :You_Rock_Emoticon:
May God bless,
Dwight
I'm trying to imagine this. So if you took the 48 in rule when it's flexed and tied, and laid it on a table with both ends flat, the middle of the ruler would be 6 inches above the table top. So you're curving the entire piece 6 inches over the 48 in total length. Is that right?
Ann
May God bless,
Dwight
Ann
Sorry, Ann, . . . I should have mentioned that you lay the ruler down on the table on it's edge, . . . that gives you the first curve which will become the top edge of the belt. The pencil compass/dividers then scribes around the ruler line to give you the proper curve for the bottom.
Take a look at the enclosed sketch.
May God bless,
Dwight
