Members desertw0lf Posted August 3, 2010 Members Report Posted August 3, 2010 Have a question - can I dye a product, oil it up with Neatsfoot oil, and then use Carnuba wax as a final finish without using eco-flo or other type of acrylic topcoat? So : Eco-Flo Black Dye, Good coating of neatsfoot, Rubdown with Carnuba wax, and buff with a microfiber cloth? Or is that not enough for say, an IWB holster? Quote
Members Dwight Posted August 3, 2010 Members Report Posted August 3, 2010 This is a personal experience, . . . based on one incident, . . . I used Eco Flow Black on a rough out shoulder holster some years ago. I decided to forgo the usual Resolene treatment, . . . wanted to keep it really soft and pliable. Rubbed it down really good to get rid of the powdered residue after it dried. Wore it a few days later to a funeral. It ruined my tee shirt, got black dye all over me. Yeah, I was unhappy. Gave away the bottle of dye, use only oil based dyes now. Have not had any other similar incident. May God bless, Dwight Quote
Ambassador Luke Hatley Posted August 3, 2010 Ambassador Report Posted August 3, 2010 If it was me.....as long as there is Fiebings Black Oil Dye, that is the only dye that i will use.....then finish the item like you said. Quote
Members whinewine Posted August 3, 2010 Members Report Posted August 3, 2010 Have a question - can I dye a product, oil it up with Neatsfoot oil, and then use Carnuba wax as a final finish without using eco-flo or other type of acrylic topcoat? So : Eco-Flo Black Dye, Good coating of neatsfoot, Rubdown with Carnuba wax, and buff with a microfiber cloth? Or is that not enough for say, an IWB holster? Short answer, NO, if the dye is an eco flo product. Eco flo is water based, so, in a moist/damp/wet environment, it needs to be sealed against H2O. Carnuba is only water resistant, as is tankote & a host of other 'finishes'. An acrylic top coat is ok; my personal choice is neatlac or clearlac or saddlelac: I would rather go for a shiny finish than have someones' clothes ruined because of dye bleed. Certain things like Aussie & Pecards do quite a good job (haven't tried Snoseal, but that might work well, too), but they can leave a greasy/oily finish, that, until totally absorbed, can also bleed onto clothes. Stuff like that is better suited for motorcycle seats, boots & the like, primarily as a water proofing & conditioning agent. I did a sheridan finish on a purse once, using antique, neatsfoot & Aussie:I packed it away at the end of the season & when I took it out for the first show of the next year, it was covered with a great deal of oily/waxy residue (obviously too much neatsfoot & perhaps Aussie). By wrapping in paper towels & using a heat gun, I finally got most of the oil/Aussie to migrate into the paper towels. Just my experience: the key is to experiment & find what works, but just remember, if it's water based, it needs to be appropriately sealed, especially in damp environments. Quote
