Members Rastus Posted August 12, 2010 Members Report Posted August 12, 2010 I recently traded for a Singer 138W102. It's on a singer table with a three phase motor. Any and all info for this machine will be greatly appreciated. Its seems to be in good shape but I don't have three phase power. What is it worth if it's in good working order? I assume it will be good for chink/leggins and belts etc??? Thank You guys for help. Quote
Moderator Wizcrafts Posted August 13, 2010 Moderator Report Posted August 13, 2010 That is a post machine, with either a roller or walking foot mechanism. They are built to sew hats, shoe uppers and moccasins. You will be limited to using #69 nylon thread, tops. I don't recommend this type of machine for belts, or anything requiring a true straight sewing edge, as they don't have a means of attaching a normal edge guide. You can buy a gear reduction 300 watt, 110 volt servo motor for it from Toledo Industrial Sewing Machines: 800-362-7397. Measure the belt on the existing motor, then add two inches to the replacement belt, for the servo motor, which has a 2" pulley. They also have replacement parts, needles and bobbins. Alternately, buy a 110 volt, 1/2 HP clutch motor. Quote
Members Rastus Posted August 15, 2010 Author Members Report Posted August 15, 2010 Thank You for the information. Any idea what a working one might be worth? That is a post machine, with either a roller or walking foot mechanism. They are built to sew hats, shoe uppers and moccasins. You will be limited to using #69 nylon thread, tops. I don't recommend this type of machine for belts, or anything requiring a true straight sewing edge, as they don't have a means of attaching a normal edge guide. You can buy a gear reduction 300 watt, 110 volt servo motor for it from Toledo Industrial Sewing Machines: 800-362-7397. Measure the belt on the existing motor, then add two inches to the replacement belt, for the servo motor, which has a 2" pulley. They also have replacement parts, needles and bobbins. Alternately, buy a 110 volt, 1/2 HP clutch motor. Quote
Members BIGGUNDOCTOR Posted August 15, 2010 Members Report Posted August 15, 2010 You can also get a phase converter , or use a jack motor to run it off of single phase at home. I would recommend a rotary type converter, as opposed to the static type. These generate true 3 phase power from single phase input. A jack motor is another 3 phase motor that is as big, ort bigger in HP than the machines motor, You essentially wire the machine through this second motor. Give the jack motor a pull start, and then start the machine. I have run a 18.5"X54" Monarch lathe 5HP, as well as a surface grinder 2HP, and milling machine 2HP this way. I had plenty of free 3 phase motors available, so I went that route. The one drawback of this style is that you only get 2/3 of your rated output. Example, if the machine has a 3HP motor , you can only utilize 2HP because there are only 2 hot legs powering it. Quote
Moderator Wizcrafts Posted August 15, 2010 Moderator Report Posted August 15, 2010 Thank You for the information. Any idea what a working one might be worth? I bought a 300 watt gear reduction servo motor from Toledo Industrial Sewing Machines, for $176 shipped. I ordered before 3 PM, EST, and it arrived the next afternoon. I also ordered a 2" shorter (not longer!) v-belt and I'm glad I did. The Servo motor mounts closer to the underside of the table and has a fixed 2" pulley. If the original motor pulley is 3 or more inches, you may need a 3" shorter belt with the servo motor. Tell the salesman what size belt is on the machine now and what the diameter of the pulley is. Quote
Moderator Art Posted August 16, 2010 Moderator Report Posted August 16, 2010 I've never seen a 138w102 with anything but twin needles and bobbins, usually 3/32 or 1/8 gauge for shoes. You can also swap out a 1725 rpm clutch motor for $50 or less, but a servo would be better, it might have the old exposed clutch on it already. Cleaned up and running with a smaller gauge (they could have up to 3/4 inch) maybe $300, maybe a lot less. It is not a rare bird so it's just a sewing machine. The 138w103 had a better set of hooks and could take larger thread. Art Thank You for the information. Any idea what a working one might be worth? Quote
