terrymac Report post Posted September 23, 2010 Have a question for someone with more smarts than me, is there any difference between skirting and tooling leather other than the obvious weight difference? I always assumed they were one in the same with the skirting just being a heavier weight. I read somewhere that skirting leather is actually tanned a little different, and I am curious if this is true. I've also heard of craftsmen using only skirting leather and having it skived down to a 8 to 9 oz range, supposed to tool better? Anybody have any ideas? Thanks for the help, Terry Quote Share this post Link to post Share on other sites
Randy Cornelius Report post Posted September 23, 2010 Skirting leather does have a different tanage than tooling leather but that will vary greatly from one tannary to another. Skirting is usually more firm for added strength a durability for saddles and tack. It will have a slightly darker color than tooling leather. Skirt will be somewhat larger sized hides because it's main purpose is to build saddles. I do order skirting leather split down to 8/9 or even a 5/6 depending on the project. When making a large case I do this as stated the skirting leather is most times a larger hide. The tooling leather will have a softer tanage to accept the tooling better in some cases. It will also have a lighter color than the skirt and the hides somewhat smaller. Quote Share this post Link to post Share on other sites
terrymac Report post Posted September 23, 2010 Thanks Randy for the info. That is what I was wondering. Terry Quote Share this post Link to post Share on other sites
Luke Hatley Report post Posted September 25, 2010 ....AND if you buy from Tandy read the fine print, the thickness on the Butt could be 10-12 oz the shoulder 8-9oz. this could cause problems if you cannot thin it . I get mine from Wickett & Craig, specified as to what thickness i want. Quote Share this post Link to post Share on other sites
terrymac Report post Posted September 25, 2010 Luke, Thank's for the heads-up. Anybody try the skirting that Siegel's is having tanned to their own specs by Wickett-Craig? Terry Quote Share this post Link to post Share on other sites
