the moisture shouldnt be a problem with a mohair cinch. just make sure you hang it so it can dry between rides.... mohair is very comfortable for horses and wont burn them when wet like a leather or neoprene cinch sometimes can.
TRACY
MONSTER FARM SPECIALTIES-custom tack for dog, horse and human
  • Replies 20
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
He is a gray dun. My other horse is a Haflinger gelding! Both need to have their front leqs stretched after being cinched up.
The saddle came with a back cinch, but it was too small. The saddlemaker is making him a larger one.
Glad to hear mohair can take getting wet. I'm a total newbie to mohair!
I know someone already replied with what I was going to say, but I wanted to add something. I went to The Boot and Saddlemaker Roundup at Witchita Falls this weekend and met another member of the forum who in discussing using nylon vs horsehair or mohair for mecate reins, gave me some good advice he heard from somewhere else. The cowboys 100 years ago worked out in the rain, muck, and mud on a daily basis and had no means of protecting or treating their gear further than normal, and didnt worry about it getting wet. As long as you properly dry something between uses and dont let a rawhide bosal or a mohair cinch sit around the tack room wet for days, you should have no problems. If it gets rained on, I would just take it off the saddle and maybe hang it up. That way it gets some air circulation and doesnt lay across your saddle wet.
CW
Again, thank you for the advice! Yes, this is a five year old Norwegian Fjord gelding. He is short-back, wide with a big barrel and a honking thick neck. He has personality-plus and very smooth to ride. I have spoken to a cinch maker, and he has suggested a 38" mohair roper cinch. I trail ride and it rains a lot here. Time to do some research on how to keep a mohair cinch clean in a wet environment. I have never used a string girth/cinch before. I am very grateful for this forum with its wealth of hands-on knowledge!
:You_Rock_Emoticon:
to solve the wet cinch problem, get 2 cinches then you can dry one out if you are riding every day. I know cowboys around here that ride every day in wet conditions that have 4-5 cinchs to make sure they always have a clean dry chinch on their horse. 5 would not be neccesary for you but 2 might help you out.
check out www.stevemasonsaddles.com
check out my saddle blog
While I am picking everyones' brain - how do I know what width of cinch to get, or do I just go with the cinchmaker's suggetion of the roper cinch? The mohair cinch is 5" below the cinch ring and 10" a the center of the belly. My Norwegian Fjord is not fat, just built like a tank!
Just throwing in my two bits,and not intending to contradict anyone. You do need a longer cinch I agree but you'll never cinch that saddle up three inches rear of where it is and keep it there, it's not as simple as that, that cinch or any cinch will naturally find it's way to the smallest part of the horse, it's cinched in the girth of the horse in the photo and even if you deliberately move it three inches back it will find it's way back right where it is in the first mile. This is why the old centerfire rigged saddles were so well known for moving all over a horses back, because cinching a horse around the tapered part of his body only happens with limited success. There is nothing wrong with it cinching slightly forward like it is, most saddles appear like yours to some degree unless they're rigged full double. If you're concerned about a dry, cinch I think the two cinch idea is a sure thing. There is a difference between what most call a roper cinch and just a wide cinch, the roper is usually woven solid several inches directly beneath the cinch buckles and then the strands single out. A plain wide cinch isn't woven at all, the strands are loose all the way from the center to the buckles. The plain wide cinch will dry quicker and stay cleaner than the woven together roper style because the strands can separate full length of itself and tend to dry better and also sweat, hair and dirt doesn't build in them as quickly as the solid woven roper style.The roper style seems to be very common and the loose strand wide cinch is more difficult to find in our area but if you're dealing with a cinchmaker and not just shopping what's locally available you should be able to get one if you'd like. Hope that makes some sense.
I spoke with the cinchmaker tonight. He asked me to measure from the horse's elbow (mid-point) on one side then underneath to the other elbow. I will also send pictures of his front-end and side. This will help him decide on the correct width and length to make the cinch.
I have found that the single ply cinches tend to stay in place on the horse the best. Roper cinches are stronger because the strands are doubled. As Jim said, they are woven together several inches from each ring, and then spread flat in the center. They are usually 29 - 31 strands. The single ply cinches have looser strands, and intertwine with the horses hair and tend to hold their place better than doubled roper cinches. A 19 or 21 strand double diamond or three bar 100% mohair cinch in the correct length would give you satisfactory results. I stock these in my store and can get them for you in extra long lengths if you need additional assistance.
Keith
Keith Seidel
Seidel's Saddlery
www.seidelsaddlery.com
Icelandic tank owner here. When I finally finish a tree that fits my guy, I'll be using a joined/pack cinch like this:
http://store.artcord...cinch-p180.aspx
They work quite well on these sorts of horses.
Edited to add a photo of my horse in a borrowed Harwood saddle (93 degree tree). The owner had ridden a couple of Fjords in it the year previously, and said the saddle (and cinch, by extension) fit reasonably well. It was okay for my horse, but could have used a bit more rock I think. I think he would have been a bit happier in the pack cinch, but this worked fine for the clinic in question.
post-5885-007273700 1286305721_thumb.jpg.
Cheers,
Adam
Edited by AdamTill
